Scratch Build – In Progress The Wood Brothers
Discussion in 'Project Logs' started by Razarach, 24 Dec 2012.
  1. Razarach
    Razarach Minimodder
    28 Jan 2009
    Only few pics.
    True Black Apogee XT :D
  2. Razarach
    Razarach Minimodder
    28 Jan 2009
    Small update after long time.
    I paint rest of fittings.
    Also i finished custom water blocks, and put orings in.
    And finally mounting system for hard drives is done.
    Next update within few days.
  3. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    I think you mounted the top left top wrong, the flow wont flow with that orientation.
  4. Pranja
    Pranja Blackwolf
    18 Dec 2011
    +1
    Razarač, okreni donji dio bloka za čipset.
  5. Razarach
    Razarach Minimodder
    28 Jan 2009
    I did it, but after taking this photo.
  6. Razarach
    Razarach Minimodder
    28 Jan 2009
    Long time no see. Time for new update.
    PSU sleeving is done.
    And soon I will mount a few tiny details for better cable management.
    HDD case is nearly done.
    I needed in/out ports for connecting external radiator with rest of the loop.
    Drilling holes. Done! :D
    Mounting fittings.
    And finally eye candy details. :D
  7. KidMod-Southpaw
    28 Sep 2010
    So, much... GORGEOUS!
  8. Razarach
    Razarach Minimodder
    28 Jan 2009
    Thanks! :)
  9. Razarach
    Razarach Minimodder
    28 Jan 2009
    Small update. I decide to go with clear acrylic tubes.
    Till now i didn't have chance to bend this kind of tubing, so I spent some time trying to get perfect bends.
    After bending I cut tubes at same size.
    I still need to bend one tube, and redo pump to first block tube.
  10. Razarach
    Razarach Minimodder
    28 Jan 2009
    After some thinking I find place for hard drive.
    Testing height and drilled holes. :D
    Standoffs with rubber. Hope this will kill hdd vibrations.
    Mounted on railing.
    After painting I put PSU together and mount hdd.
    And HDD power. :D
  11. Razarach
    Razarach Minimodder
    28 Jan 2009
    New update. :D
    After short break I'm done with pipe bending.
    After a few unsuccessful tries to route pipe on right side I decide to go with this shorter, simpler but not that pretty line.
    I filled loop today to check for leaks, and to clean pipes, and blocks. Tomorrow I will fill loop again and test Mayhems blue dye. :D
  12. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Brilliant idea for the HDD placement. :thumb:
  13. Razarach
    Razarach Minimodder
    28 Jan 2009
    Thanks! :)
    Today I filled system again, and added some Mayhems Blue. :D
    I will add some more color to get darker blue, and need to make some sound proof box for pump.
  14. Cheapskate
    13 May 2007
    Looking pretty.
    The sound may be more from what the pump is mounted to. A box would just overheat it.:D
  15. dombak1608
    dombak1608 What's a Dremel?
    3 Apr 2012
    Amazing build, dude! :clap:
  16. Razarach
    Razarach Minimodder
    28 Jan 2009
    Thanks! :)
  17. Piotrek_PL
    Piotrek_PL What's a Dremel?
    29 Mar 2013
    Looks grate mate but if I were you I think I'd use a smaller rad and put it inside the case.
  18. Razarach
    Razarach Minimodder
    28 Jan 2009
    Thank you! :)
    I was thinking about smaller rad but somehow this option suits better for me.
  19. WaRn00b™
    WaRn00b™ bit-tech addict
    14 Jan 2013
    Awesome build - I must agree with what was said as well - if I were you, I would've installed the triple rad in the front or top of the case instead of outside, seeing that the wood case was completely custom built anyway.
    Why, if I may ask, did you go this route anyway?
    Nice none the less! :)
  20. Razarach
    Razarach Minimodder
    28 Jan 2009
    Thanks!
