Case Mod - In Progress Tundra EVO TJ07- Nope not dead!
Discussion in 'Project Logs' started by fr0Zen, 16 Nov 2012.
  1. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    Teaser picture of the day:
  2. Asouter
    Asouter --------
    18 Jan 2012
    I liked the pic of "bits all over the house" That's not half as bad as what I'm like ..... it's always a fine line to tread when you need your kit to hand and keeping the other half pacified.
    Liking your project :thumb:
  3. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    just my luck that school leaves me with two hours pr day, without parents:)
  4. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    just a small update today. I painted the mobo heatsink
    //PWE
  5. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    Okay so a fair bit of progress. ive fallen in love with these casefeet.... Bill Owen makes them= awesome= out of my buget:(
    http://www.mnpctech.com/computer_feet_machined_aluminum_mnpctech.com1.jpg
    some more bad news. my painting skills arent that good this is the mobo heatsink..... i will have to live with it.
    i changed the skrews for the top exaust fans, these are way better.
    I finaly got the cpu cutout made, it is not perfectly aligned but it will work.
    testing to fit fancontroler
    i also found a place for the hdd :)
    the front mesh makes airflow no problem
    its just mounted with a pice of sandet plexi
    just two showoff pics here :)
    i need a EK multioption 250 advance res so if you have one let me know :)
    All feedback is appreciated
    That is it for this update.
    //PWE
  6. AverageNinja
    AverageNinja Almost an EpicNinja
    6 Aug 2012
    Noice! Will you be painting the interior? The steel looks a bit out of place IMO
  7. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    not steel alu. but yes, well sort off i plan to use dinoc and paint to cover all the bad parts.
  8. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    update later here is a teaser
  9. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    Overkill pumpmount
    first mount the pump to some plexi
    then bend with heatgun
    Cut to fit ing the case
    Done
    test fit
    holes drilled for mounting to the case
    add some foam, skrews and some parts of a noctua holddown
    Done!
    First modding injury
    some proper shots of the cablemanagement
    and this is what makes it possible
    one of the skrews goes thru the mobo tray and then in to the back of the standoffs
    thats it for today :)
    //PWE
  10. The_Crapman
    5 Dec 2011
    Lookin really good mate. Can't wait to see how it finishes :)
  11. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    sadly its going to take a while.... :p
  12. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    Midplate
    first i made a template and found some nice mahogany
    then cut and shape to fit in the case
    overall shot
    i still need to remove some material to make room for the mobo tray, but i killed the cutter i before i could get to cutting it. so when i was ready to cut and it was up to speed i was showered in green plastic from the indside of the cutter....
    //PWE
  13. do}{tor
    do}{tor What's a Dremel?
    21 Dec 2012
    Hi! :D
    And unless it is possible to use this pomp in vertical situation?
    This pomp not self-soaking up, extremely isn't recommended to have its soaking-up union down as fast wear of an imeller and the bearing is possible.
    Or I am not right? :geek:
  14. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    well there will be a 250 mm res above so there will be some water pushing it self in to the pump. after all it is just a ddc and i have seen a few with the pump on the side:)
  15. do}{tor
    21 Dec 2012
    I am sure you know that you do, good luck :thumb:
  16. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    Lol i dont know anything about pumps:D
  17. Hukkel
    Hukkel James' minion
    20 Dec 2012
    What is up with that double bottom fan on the radiator?
  18. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    im just using the shroud to get a more organic feel
  19. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    midpate is now done :) here are the cornersto make room for the skrews that hold the case
    masking off where to cut
    got some more masking tape
    final cut with the tape
    and no tape
    its not perfect but good enougth :)
  20. JULO
    JULO What's a Dremel?
    2 Jul 2010
    The ATX 24-pin cables and SATA cables: I would make holes right next to the MoBo, so they go to the other side by the egde of the motherboard, in my opinion that would look way cooler ;)
    I have an impression that now the cables itself attract too much attention
    But besides, the whole project looks great ;)
    And if I can suggest something more, think about good lighting to expose the facture of the mahogany ;)
