Case Mod - In Progress Tundra EVO TJ07- Nope not dead!
Discussion in 'Project Logs' started by fr0Zen, 16 Nov 2012.
  1. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    im going to create a coverplate that will make this all nice and clean
  2. AverageNinja
    AverageNinja Almost an EpicNinja
    6 Aug 2012
    I like that mid plate! Unique for sure!
    Keep it up!
  3. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    it was either white acrylic like the murdermods og this nice wood i already had :)
  4. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    Ihave just sold my coolermaster smp gold 600w to a freind. So im getting a evga supernova 750w gold is got the power to run both my 6950, so im going to do so, however the one im rumming now has a black pcb and backplate. The other one has a red pcb and no backplate, otherthan that it isent a reference pcb so the block is different. Im considering making a box/ covering plate for both the gpus.
    //pwe
  5. Dragulax99
    Dragulax99 What's a Dremel?
    9 Apr 2012
    does painting the heat sinks effect the board in any way ...what kind of paint did you use...and finally did you remove them and then paint ....awesome job btw keep it up ...
  6. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    i dont know yet. some cheapo mattblack acryl spray paint. i just skrewed them off, masked off where the thermalpads go and then gave it two layors. Thanks man :)
  7. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    It didn't effect mine. I painted the green/brown heatsink blue to match the rest of my white and blue tj07 build.
    In fact the temps are really good!
  8. Dragulax99
    9 Apr 2012
    cool ...i have an Intel board and a red and black theme was considering painting the blue heatsinks red or black ...but didnt know what affect that would have ...not too many Modders painting motherboard heatsinks now adays ....:rock:
  9. bdigital
    10 Aug 2010
    I should probably point out that I only painted the small southbridge blue. The misfits around the cpu i have under water. So im not sure of the effects it would have painting all of them?
  10. Dragulax99
    9 Apr 2012
    we will soon find out...lol :D
  11. whyte
    whyte What's a Dremel?
    27 Mar 2012
    very cool... keep up the good work
  12. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    psu is gone. now to get pictures to my rambeling
    the new gfx below its tigth.
    that all for now i have 3 major papers this week...
    //PWE
  13. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    Okay so i need your help to decide if i should make a GPU backplate for the red card or a box cover for both GPUs
    TELL ME :)
    //Peter Wibe Enevoldsen
  14. woody_294
    woody_294 Wizard Ninja :P
    31 Dec 2008
    Backplate!
  15. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    anyone else??
  16. The_Crapman
    5 Dec 2011
    Yeh a back plate i think. If they were air cooled cards it would have been cool to make a case around them with a fan forcing air in and out the back, but not any point if they're on water.
  17. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    backplate it is then :)
  18. wejjy
    wejjy Minimodder
    9 Aug 2010
    Agree on the backplate mate, its looking real nice, keep it up, after your papers are done! Priorities :)
  19. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    i would only make one for the lower red GPU, as it is the ugly one... possibly make a clear plexiplate to go over the original black one.
    //pwe
  20. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    In a stroke of insanety i decidet just to go with an AX760i its pricy but its 80+ Platinum and will run my dual HD 6950s
