Case Mod - In Progress Windows G5, 24 October FINISHED
Discussion in 'Project Logs' started by sk8roy, 12 Sep 2009.
  1. sk8roy
    sk8roy What's a Dremel?
    12 Sep 2009
    Well been busy installing hardwood floors, but finally got some time to work on this. A small change with the lighting. When trying to extend the cables on the CCFLs they would not light properly when I was done. They were very dim and when I sleeved the wires together they would not light at all. I first thought it was my soldering job so had my buddy come over and redo it, the same thing. He said were the soldering spots were the heatshrink was not a good enough insulator, not sure if that is true but they no longer worked right. So switched to leds. They are brighterfrom the loos of it and still worked after extending the power leads.
    a few pics of them.
    36 leds
    x4
    Case not lit
    lit up
    They look like they light a little more of the case up, so that is good.
    Should have an update of the dvd install tomorrow. Need to get some pics of it. I think I finally got it thanks to bouly.
    Till then enjoy and thanks for lookin............
  2. Richh999
    Richh999 Small Time Modder
    9 Oct 2008
    The LEDs look good although it does seem as though there is a dim patch in the middle of the bottom plate. oh well, the advantage of the leds is that you could also do flashing or patterns with them if you add a controller..
    Anyways I love it still and keep up the good work...
  3. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    Noooooooooo... (Throwing myself between the dremel and the G5 case)
    Drama aside, this looks really good, I'm gonna follow this! :)
    /Subscribed
  4. sk8roy
    12 Sep 2009
    Finished mounting the DVD this morning. My original plan was to use the aluminum strips I had left over to make some what of a bracket to mount it. After seeing bouly's post I ditched that plan and went about using the original clips that came with the case ( I completly forgot about them ) I glued two washers together for the spacers to raise the drive up to the right hieght and glue them over the bottom mounting holes. Screwed in some bolts that had the right size head for the G5 clips to grab ahold of properly. Here are some pics and made a video. Video is not that great, Used my Moto Q9c.
  5. sk8roy
    12 Sep 2009
    Put most of it together and fired it up to make sure everything was working. Several problems to work out and then I can paint and put do a final build. 2 fan cables are too short, the aftermarket pci connectors were %#$ up. The middle pin on the top is suppose to be rounded off but it is square, will either have to try and round it off myself or will be using the stock red connectors. So now I off to tear it back apart, extend and sleeve my fan cables, work on the pci connectors and paint this puppy.
    On the bright side successfully installed win7 even though asus said the board did not support it and temps are low even though I'm only using 2 fans at the moment.
    Next update should be the last final assembly
  6. Bouly
    Bouly What's a Dremel?
    23 Oct 2008
    Nice
  7. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Win 7 is compatible to almost everything as far as I have experienced. :D
    Looking great, LOVE the blue/white cables!
  8. sk8roy
    12 Sep 2009
    Ok, well this update isn't the final build like I said the next one would be but had to share my painting results. All I did so far was the cover for the cooler.
    Before
    After
  9. perplekks45
    9 May 2004
    Looks a lot better but I still don't like the dragon in the middle. And if you really feel like it: Why not sand away the ASUS logo?
  10. sk8roy
    12 Sep 2009
    Some more painting. Also modified the side window so the entire fan could be seen through the side. I hoping I have enough plexi to cut a new piece, if not back to the hardware store...
  11. Bouly
    23 Oct 2008
    Happy that my experience your helping for the assemblage of your dvd :rock:
  12. sk8roy
    12 Sep 2009
    yeah thank you alot. You know I completely forgot about those clips.
  13. perplekks45
    9 May 2004
    /me likey a lot!
  14. sk8roy
    12 Sep 2009
    Recieved 2 of my 4 fans today. These should go with the case alot better than the ones I was going to originally use.
  15. tyrandan
    tyrandan Pink Lemonade.
    2 Mar 2009
    SWEET MOTHER OF SPICY EYE-GOUGING JALEPENOS! WHAT HAVE YOU DONE TO THIS LANDMARK OF MODERN DAY COMPUTER SYSTEM HOUSING!!!!
    .... A fantastic job, that's what! And I see you are using my favorite color, blue, for the color scheme.... +rep! (also, great work for the lighting unit with the 144 LEDs! I think you should paint the wood housing black, but w/e, it looks great nonetheless!)
  16. Saivert
    Saivert Minimodder
    26 Mar 2005
    yes, as stylish as gray aluminium is it does get boring when it's used as much as it is. And Apple does seem to be a bit locked on a track here.
    I myself have a BLACK Lian Li case. I just love it.
    I liked the cut out Windows logo. It will shine through here lovely I bet. Looking forward to pictures of that.
    Are you going to put some mesh behind it too?
  17. sk8roy
    12 Sep 2009
    I am going to put a piece of white plexi on the inside of the logo and stick one of those LCD boards behind it. It should light it up pretty good.
    preview of the paint...still have a few more coats of clear to go.
  18. The boy 4rm oz
    10 Apr 2008
    The white and blue looks very nice :thumb:.
  19. perplekks45
    9 May 2004
    It looks kinda oldschool. Couldn't explain why but it does to me.
    And I LIKE IT! :)
  20. WolfandAngel
    WolfandAngel Got fins?
    2 Dec 2008
    looking good
