Scratch Build – In Progress ZdMods - Project pǝʇɹǝʌuı - Final Pics! (post #273)
Discussion in 'Project Logs' started by Meelobee, 8 Mar 2012.
  1. spolsh
    spolsh Multimodder
    4 Feb 2012
    looks amazing ... strange thing is, i find my eyes drawn to the cases feet - the way you've done them is fantastic. (and i don't normally have a thing for feet LOL)
  2. jhanlon303
    7 Sep 2006
    I like this a lot. I watch.
    john
  3. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Thanks :) And yep I'm making a custom case for the psu:
    I'm not sure if I should be happy or worry about you liking my feet ;) thanks!
    :thumb:
  4. wilkinson001
    wilkinson001 What's a Dremel?
    24 Feb 2012
    This looks great, i love how clean and symmetrical the rads look, doesn't happen very often. +sub
  5. Meelobee
    5 Nov 2003
    Thanks wilkinson :)
    Did a bit more work on the psu, mounted it on the bottom panel of the case and I've made the holes for the connectors in the top of the psu:
    (The long screws on top will ofcourse be cut to lenght.)
  6. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    this going to be a very special build, me like! :thumb:
  7. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    I got to agree with kelmannen. Very special, and it looks darn good! :thumb:
  8. Meelobee
    5 Nov 2003
    Thanks guys :)
    Dispite of the hectic last couple of days (I became a daddy yesterday!!) I did manage to find some modding time. I've evened out all of the 'corners' of the frame. The frame, the plexi strips and the aluminum panels now all are the same size. I still need to do some small corrections with a small file, but it looks quite nice already:
    I've also countersunk the screws on the left side of the case, looks alot cleaner this way:
    Up next is finishing the PSU housing and placing the pump :)
  9. Meelobee
    5 Nov 2003
    I've cut the hole for the pump/reservoir:
  10. Meelobee
    5 Nov 2003
  11. A80
    A80 What's a Dremel?
    22 Mar 2012
    PSU mod is shweet. favorite part of the build so far.
  12. Meelobee
    5 Nov 2003
    Thanks A80 :)
    I've finished the 2nd pass-through to the top of the case and connected some of the parts to check if everything lines up correctly:
  13. dirky90
    dirky90 Minimodder
    19 Mar 2012
    what tools are you using to do this? its all so clean, great work
  14. Meelobee
    5 Nov 2003
    Thank you Dirky!
    For the aluminium and plexi I just use basic tools:
    A couple of big files to get rid of the big chunks, smaller files for the details, sandpaper to smooth the edges. Most important is alot of patience :)
    The_Crapman likes this.
  15. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    This looks fantastic.
    I love the way you used the fittings... it gives more of a industrial look to the build :)
  16. theoeyeo
    theoeyeo What's a Dremel?
    27 Nov 2011
    :thumb: great work so far. what are your plans for lighting?
  17. The_Crapman
    5 Dec 2011
    Looking really nice already. I'm a big fan of straight wc tubing so muchos repos!
  18. Meelobee
    5 Nov 2003
    Haven't had much time to mod lately, but I found some time to get this done:
    I've countersunk the screws in both sides now, which gives the whole case a much sleeker look. I've also added some ledstrips in the top part of the case. For the lightning I've ordered a RGB Led Controller with remote control.
  19. Balder
    Balder Calmer than a monk on morphine
    4 Jul 2003
    Case looks sweet and congratulations on the +1 earlier! (I hope you get more sleep then I get!)
  20. Foregasm
    Foregasm What's a Dremel?
    3 Apr 2012
    subbed. i absolutely love what you did with the acrylic.
