Scratch Build – Complete ⭐ [ COMPLETED ] The Time
Discussion in 'Project Logs' started by MPC, 5 Feb 2017.
  1. MPC
    MPC Minimodder
    24 Oct 2015
    My project is called “The Time”, characterized by elegance, precision and attention to details while looking the aesthetics impact by using colours’ contrast like silver/gold. The structure will be supported by aluminum profiles wrapped in mahogany and will provide the base of the case in which will be housed the PC liquid cooling system. From the base there are 8 polished aluminum pillars which will allow the securing of water tanks made with green plexiglass.
    Inside one of these tanks a clock is placed and the PC cooling liquid. In the other tank there are the hardware parts, also set while trying to organize the cables in a non-chaotic way.
    CPU : Intel i7 7700k
    MOTHERBOARD : MSI Gaming M5 Z270
    VGA : MSI GTX 1070 SEA HAWK
    RAM : Corsair DDR4 Dominator Platinum Special Edition Chrome 4x8 GB 3200 MHz Limited Edition 292/500
    SSD : Corsair Neutron XTi 480 GB X2
    PSU : Corsair AX1200i
    DEVICE :
    - Corsair Gaming K70 RGB RAPIDFIRE Mechanical Keyboard
    - Corsair Gaming M65 PRO RGB Gaming Mouse, Backlit RGB LED, Optical
    - Corsair Gaming MM800 RGB POLARIS Mouse Pad
    - Corsair Gaming Void Wireless Gaming Headset White
    AIR COOLING :
    - Corsair HD Series, HD120 RGB, 120mm Individually Addressable RGB LED Fan, 3 Fan Pack, With Controller
    - Corsair HD Series, HD120 RGB, 120mm Individually Addressable RGB LED Fan, Single Fan X3
    LIQUID COOLING :
    - Alphacool Eisbrecher Pro XT45 Full Copper 360mm radiator X2
    - Alphacool Eispumpe VPP755 - Single Edition X3
    - Alphacool Eiszapfen 13mm HardTube compression fitting G1/4 for plexi- brass tubes (rigid or hard tubes) - knurled – chrome
    - Alphacool HardTube 13/10mm brass chrome 40cm
    - Phobya touch 630 controller
    - Many other chrome fittings at 90 °, taps, bulkhead, flow meters and more
    SLEEVING GOSUMODZ :
    - PLX Sleeve Desert Gold
    - PLX Sleeve Silver Grey
    - Alliance Comb Closed 24,14,10,8,6 Pin Natural
    - Alliance Comb Closed 4 Pin and 5 Pin Single Row Natural
    - Thumbscrew UNC 6-32 and M3 Gold
    - Connectors and terminals
    - Single wire black
    - Tools : Knipex Wire Stripper and Mini-Fit Jr. Extractor Tool
    STRUCTURE MATERIALS :
    - mahogany wood
    - aluminum profiles
    - grills drawn
    - plexiglass soft fluo green
    - brass
    Sponsored by:
  2. MPC
    MPC Minimodder
    24 Oct 2015
    The planning took a lot of time for an accurate study of the system of perfect gears to recreate the correct time. After it switch to draw on specific softwares 2D and 3D the gears that are carried out with cnc pantograph in inner sections and the teeth are manually operated .
    Creation of the linchpins to keep suspended the clock through stainless steel cables on tank containing the liquid cooling of the pc.
  3. Cheapskate
    13 May 2007
    It's looking to be a promising year for mods. :D
  4. Vault-Tec
    30 Aug 2015
    This gun be good ! the first time I have ever seen a case that will be as heavy as Nexxo's :D
  5. MPC
    MPC Minimodder
    24 Oct 2015
    @ Cheapskate : Thank you :)
    My Mod are always special realizing something never seen before. I go out to the standard :D
    @ Vault-tec : ahahah surely it will have a good weight by calculating the much material that distinguishes this project: aluminum profiles, mahogany wood (among the heaviest woods), aluminum tubes, tanks plexiglass, PC and at least 5 liters of liquid to fill the tank clock.
  6. Nexxo
    23 Oct 2001
    Yeah, you want to do those weight calculations. Ada is small, but surprisingly heavy!
    And you cut those gears by hand?! :eeek: Impressive. I'd do them on a mill with a rotary table and dividing plate...
  7. MPC
    MPC Minimodder
    24 Oct 2015
    Thank you, Nexxo :)
    Yes, I have had to do all the teeth of the gears by hand because the small distance between them did not allow me to use the milling cutter at least 2 mm and do everything with the CNC. Then if you remember my previous project "The Stagecoach Wells Fargo" where I made every part of brass on handmade , I'm not afraid to do many things by hand.
    I have followed your Ada project and is very special. :thumb: These are the projects that I like very much because they are new forms and things never seen before. This is the thinking that is found in my projects. In short, there was still no one who has made a working clock and plunged into the liquid that cools the PC.
    The heavy weight of your project is given by the very strong structure with aluminum plates. You're doing a great job painstaking attention to every detail :thumb::thumb::thumb:
  8. MPC
    MPC Minimodder
    24 Oct 2015
    Anodization of various gears, pins and plates both for an aesthetic factor and to avoid galvanizing Because the clock will be immersed in the coolant.
  9. MPC
    MPC Minimodder
    24 Oct 2015
  10. MPC
    MPC Minimodder
    24 Oct 2015
    Bonding pins and gears with industrial glue to permit gluing also in water.
  11. Nexxo
    23 Oct 2001
    Looking awesomely steampunk! :thumb:
    Just some advice (in case you didn't already know, but I suspect you do as you're right there making a whole clock after all): be careful when you space the cogs that they run as free as possible. Mesh them just a tiny bit too tightly and the friction builds up through the whole mechanism and the thing seizes up. Many a clock maker has been driven crazy by this.
  12. MPC
    MPC Minimodder
    24 Oct 2015
    Thank you very much :thumb:
    Thanks for the advice they are always welcome. You're absolutely right, and in fact I've run the clock out of the tank and I will submerge prior to another tank containing water. This way I expel some residue processing :)
  13. babydragon_64
    babydragon_64 What's a Dremel?
    14 Jun 2016
    This is an amazing looking build :)
  14. MPC
    MPC Minimodder
    24 Oct 2015
    Thanks babydragon ;)
  15. MPC
    MPC Minimodder
    24 Oct 2015
    First assembly test.
  16. MPC
    MPC Minimodder
    24 Oct 2015
    After a CNC cut ,finally comes a bit of aluminum sheets and proceed into the opening of 8 hole in the tube for insert plexiglass reservoirs.
  17. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Somebody's making a killing at the recycler's.
    Great stuff, I really enjoy seeing stuff like this build!
  18. MPC
    MPC Minimodder
    24 Oct 2015
    Thank you so much Kayin :)
    Surely these are particular mod connoted also by a long planning and the use of quality material.
    I wanted to join in this mod several key points such as aesthetics, functionality, harmony and precision with the main theme that the clock is made by me.
  19. Cheapskate
    13 May 2007
    Clock looks great. :D
  20. MPC
    MPC Minimodder
    24 Oct 2015
    Thank you so much Cheapskate :thumb:
    Surely more ahead it will be even better without those cardboard hands :D
