Case Mod - In Progress Mac G5 Mod. arg-ist
Discussion in 'Project Logs' started by arg-ist, 25 Nov 2014.
  1. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    This time my case to mod is a classic. Powermac G5. One of the most popular and ,one of the most modded beauttiful case ever made. As robustness , ı can say it is a PANZER.
    someone showed his love like ...
    Some prefer to use such
    Powermac G5 is one oft most modded case. but most of them, changed outlook of the case
    My goals for this Project were to preserve the look of the case at outside ;and fit my PC s hardware including a full ATX MB. And watercooling.
    I will to mod at two stages
    First the mod on the case and and convert it for an ATX-reverse ( like BTX) MB …
    Thenn as second mod this case for Watercooling… with acrylic tubing and alphacool capecora passive rads 642+142= 742
    To use an ATX(reverse) mainboard at this case, the back panel must be changed.
    İf we wannt to adapt the case to new motherboard. We must change
    At the back panel, the fans must be moved off center, to make a new I/O. and a larger room
    for 7 slots
    There are a lot of mods, one of them is ,
    to make a half mask as Ben Katz did.
    Link: http://build-its.blogspot.com.tr/2011/04/how-to-fit-your-pc-in-power-mac-g5-case.html
    and mount them to thecase
    Or we can use a MB tray with backpanel as gibsonc did.
    Link : http://www.insanelymac.com/forum/topic/281165-powermac-g5-case-mod/
    And cut the case, to make a space
    And mount it
    But I wannt to make a new back panel complett. With new fan holes , I/O and slots.
    I wannt to use the original fangrill as well.
    Drawn at corel... but ı musst make nearly 3000 circles with 3mm Radius..
    And sent to water jet for cutting….
    OTHER WORKLOGS
    12 Angry Men 900D Spider Web Case
    http://forums.bit-tech.net/showthread.php?t=288590
    PlayDoh Silverstone TJ07 - Acrylic tubing
    http://forums.bit-tech.net/showthread.php?t=267324
    SAK SAK 900 D CASE
    http://forums.bit-tech.net/showthread.php?t=271227
    JUMBO CASE
    http://forums.bit-tech.net/showthread.php?t=266554
    TERMINATOR CASE
    http://forums.bit-tech.net/showthread.php?t=267028
    12 Angry Men 900 D Case
    http://forums.bit-tech.net/showthread.php?t=266585
    mmt 900D Case
    http://forums.bit-tech.net/showthread.php?t=266954
    How to make BENCH CASE from an old ATX
    http://forums.bit-tech.net/showthread.php?t=277334
    self made COSMOS II Clear Panel
    http://forums.bit-tech.net/showthread.php?t=277478
    Level 10GT Acrylic tubing
    http://forums.bit-tech.net/showthread.php?t=269227
  2. Jeffinslaw
    Jeffinslaw What's a Dremel?
    26 Jun 2014
    VERY interested to see how this turns out! Will be following along :thumb:
    -Jeffinslaw
  3. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Looking forward to seeing how this pans out, I've attempted a MacPro mod in the passed and have a G5 case in the loft I never got round to. I'm pretty sure their is a US company that will sell your the ATX conversion mod panel.. I'll see if I can dig out a link.
    J.
  4. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    thanks... we ll see ıf ı can achieve or not...
  5. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    update 2 29.11.2014
    İnside of the original case
    To start, ı completely emtied out the case, including the latching mechanism that holds the front side panel on;
    but be carefull , we must use latching mechanism.
    The new backpanel came from waterjet ,
    And this the new raw plate for backpanel that came from waterjet cutting
    and and new backpanel bended.
    Locations were determined to be cut in the old panel
    marked places emptied with dremel.
    Bended backplate temporarily mounted to the case
  6. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Nicely done sir.
    J.
  7. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Thanks, but there is much work to do.....
  8. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    Very nice! :)
  9. Jeffinslaw
    26 Jun 2014
    Wow! I am speechless! It looks amazing! Any details on the bending process? How did you do it?
    -Jeffinslaw
  10. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    not a very difficult task , Dude…
    With a little attention , a little patience and with a very simple crimping machine…
  11. wahoomcdaniel
    wahoomcdaniel Minimodder
    14 Nov 2003
    On the overlayed areas, will you need to redrill hole pattern so that both pieces line up?
  12. Jeffinslaw
    26 Jun 2014
    Seems simple enough... thanks!
    -Jeffinslaw
  13. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Yes ı can redrill, it is possible.
    But I'm afraid, to expand the main hole basis.expecially at dished places.
    Becouse ı can not use a benchdrill , ı must use a handdrill. And it is to much risky..
    And there are not much overlapping section.
    But the bottom can be cut slightl a little more.
  14. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    UPDATE 03.12.2014
    To mount MB tray ı bonded 3 piece 10x20mm aluminum profiles with Dewcon SF plastic steell.(epoxi)
    MB tray (in 2 piece) mounted with standoffs.(they must be sanded, and painted)
    I must make a place for PSU . to mount the PSU ı made a tray .
    And mounted psu with this tray to the case
    I made a duct from plexi for exhaust of PSU.
    R48
    Mounted duct to PSU
    And mounted the psu with exhaust duct to his place with PSU tray
    This photograph is with a Corsair AX1200 photographed. İt is 200 mm long.
    Therefore , if ı have a problem with MB , then ı can use an Corsair AX860i . It is 160 mm long…
    40 mm shorter, not to have a problem with MB and slots.
    MB tray painted alu and mounted
  15. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Original fangril mounted (from inside)
    Backpanel with mounted grills (I must find 2.2 mm phillips self tapping screws fort he grill
    The back panel brushed with 3M Abrasive Brush
    The new backpanel with I/0 slots and fan grils mounted to the case
    the latching mechanism that holds the front side panel is mounted again.
    And the side window mounted with latching mechanism.
    Case with closed sidewindow
    I must add an white vandal buton becouse the led of original Vandals is defect ,and two leds for ON/OF and HDD.
    Made 3 holes 3mm and 16 mm diameter.
    Mounted the 16mm Vandal
    And 3mm leds
    The slots painted with a alu spray.
    Through the case...
    The case before modding
    And the new case with new backpanel
    And final pictures from the new Mac G5 ATX-reverse ( l,ke BTX)
    To compare.. Original Mac G5 and the new ATX -reverse compiant Mac G5- ATX reverse
    Next update is a different modified passive Watercooling, with a Cape CORA 742
  16. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    HackJoe
    TheL4mka
    Jeffinslaw
    wahoomcdaniel
    Thanks...
  17. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    UPDATE 12.12.2014
    I want to built a watercooling system, for my modified MAC G5 ATX-reverse
    And cool CPU+MB+Videocard. And use a PASSİVE RADIATOR.(no more fans to cool)
    One loop but in two parts.as
    3XHF142 rad >CPU> MB> 4X HF 142 rad>EVGA 680 Classified> REZ. >POMP
    I want to see the case like this
    Using a passive radiator , alphacool cape cora 7x142 mounted at rear sidewindow.
    This radiators normally operate parallel .Like this
    But ı want to use it as serial .Like this
    Therfore ı must mod T-plug connectors of cape cora.. on the bottom.and block one side to to prevent fluid flow.
    And make special fittings (adapters) for connection on the top between cape cora and EK-CSQ ADAPTER 90
    using 7 piece bended 16 mm OD clear acrylic pipes, to see color of fluid.
    12mm acrylic pipe looks out very skinny to me…
    I could use 16mm OD Copper pipes too… like this…in my 800D case..
    but ı want to edd a little color to the case…
    I planned to use EK-CSQ ADAPTER 90 BLACK
    EK-HDC Fittings 16mm G1/4-black(is the best rigid fitting for 16mm acrylic)
    and bıtspower case through hole fittings-black
    UPDATE 13.12.2014
    But ı will change EK-CSQ ADAPTER 90 Black ,with Monsoon Light Port 90 Rotary Angle Adapter ¾ Black
    and ı will illuminate the pipes from inline with Monsoon LED Stop Fitting Black(without monsoon comp. Fitting)
    to get the illuminated efect with 16mm thick acrylic pipes like this
    At last ı would like to see my MAC G5 case like this…with fluid color in bended acrylic pipes
  18. Nexxo
    23 Oct 2001
    This is going to be good...
  19. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    UPDATE 02.01.2015
    Finally arrived radiators. We can continue to work.
    I mounted every cooling moduls(Cape Cora 142) with self-tapping screws on two metal bars 20X5X400mm.
    Every moduls are mounted with two self tapping screws to both metal bars
    45 degree beveled ends of metal bars
    And they are complet mounted with two metal bars to the back side window
    And case with mounted cape cora 742
  20. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Thanks Nexxo...
    But these modification is nothing by your worklogs.
