Peripherals Mechanical Keyboards. I Don't Get It.
Discussion in 'Hardware' started by Madness_3d, 29 Jan 2013.
  1. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    Okay so I can appreciate some good hardware, I can ever appreciate some good peripherals, got my nice Display, Mouse, Speakers etc, But I just don't get the Mechanical Keyboard Mania! There's a whole thread devoted to it and its huge and it just doesn't make sense!
    Is it one of these things that you have to try it to appreciate it?
    What's the point!?!?!
    Is it really any better?
    And what is the obsession with swapping keys? Are they even all the same size?
    Someone please enlighten me, there's another one of these crazy keyboards on the front page of bit-tech today and I just feel like a noob when I see the price tag! It's not even backlit for gods sake! :duh:
  2. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    Yeah, it is one of those things you have to try to appreciate. The feel of a mechanical cherry key is so much more satisfying to use than a cheap membrane keyboard. The click of a mechanical key is just so much easier and it's like you know that it's been pressed.
    Using Different keycaps is a strange hobby from my point of view as well. I use a set of completely black keys to go with my black theme. They all do fit, because all Cherry keys have the same connector for the keys. There are exceptions, but most of the time they'll fit.
    Mechanical keyboards are expensive and a Select few will truly appreciate them, but once you've bought one; you'll probably wonder how you computed without one. It's like you're using a keyboard most of the time anyway, and you have a nice gaming mouse so why cheap out on the keyboard too?
  3. longweight
    7 May 2011
    Try it, there is no point talking about it until you have tried one.
  4. Darkwisdom
    27 Aug 2011
    The Master has spoken =p
  5. longweight
    7 May 2011
    Oh also try Topre, the gentleman's choice :)
  6. Madness_3d
    26 Apr 2009
    Anywhere you know demoing them? :p
  7. longweight
    7 May 2011
  8. fuus
    fuus Misses Rep Bombs
    4 Dec 2010
    Unfortunately very limited in the UK... There may well be one or two shops in London with cheaper models on show.
  9. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    rubber domes are a bit like pressing a sponge, sort of sloppy response, and you have to push it all the way down. Mechanical keyboards each key has a spring, acts independently and provides it's own feedback, and then the various switches all have their own feel to them. Once you spend a couple of hours typing on a mechanical keyboard you will get it.
    Key caps are good as they don't really depreciate all that much if you buy good ones, obviously you couldn't sell them to just anyone, but of all the hobbies I have ever pumped money into, I think If I was to up and sell everything my keyboards would be the only thing that returned nearly what I have spent out.
  10. Cei
    Cei pew pew pew
    22 Mar 2008
    Meh, I don't get the craze either. I just don't get on with mechanicals.
  11. jrs77
    jrs77 Modder
    17 Feb 2006
    Get yourself a "cheap" Steelseries 6GV2 and test a mechanical keyboard for yourself.
  12. The_Crapman
    5 Dec 2011
    Last time i visited a Currys it was one with a PC Turd World section which had a Corsair K60 and a Razor keyboard with cherry switches on display to have a bash with.
  13. mikemorton
    mikemorton Minimodder
    5 Nov 2010
    I have a Mionix at home and a QPad at work, and I love them.
    You can caress the keys as lightly as a lover, or bash them like a boxer and they will respond precisely each time.
    Mechanical keyboards are a bit like dishwashers.
    If you don't have one, you don't think you need one.
    But if you do get one, you'll wonder how you ever did without.
  14. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    Feels better, and it's a hobby collecting keys if you want it to be. Some people collect stamps.
  15. rollo
    rollo Modder
    16 May 2008
    Useful for typists.
    Not so useful in games.
    Depending on the key type you get they will require too much force to be useful in multi touch games.
    Bf3 online is probably were they are at there worst.
    Typing a word document at there best.
    All depends on the switch type though, some are better for gamers and some are better for typists.
    I have a typist version and a normal gaming keyboard for when i game just works out easier.
  16. TheDodoKiller
    TheDodoKiller Minimodder
    23 Oct 2011
    I have to spend time at college using a crap dome keyboard. I come home, and typing on my keyboard at home is like someone gave me 20 cans of redbull.
    so precise, you'll never miss a key with a mechanical.
    If you can relate to it, think of a dome keyboard as a haribo cola bottle. it squidges, and gives you then knowledge that you have pressed it, albeit not very nicely.
    A mechanical is more like crunching a crisp with your hand. you know when it happens, you feel when it happens- it's a very positive experience. Although you don't break a mech keyboard when you use it.
    To me, the difference is more that the mechanical feels like an on off switch, and the rubber domes feel analogue.
  17. RedFlames
    23 Apr 2009
    I had a mechanical kb... hated typing on it and it wasn't long before I broke it...
    Though my typing is equally bad on membrane KBs
    however like mice and speakers/headphones, keyboards are a subjective thing
  18. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    To clarify this statement, there is only one mainstream switch type (out of 5 or so) for which this may be true, and even then it's preference.
    Sorry I have this thing against making generalizations from your own specific (not very representative) observations, no offence meant!
  19. Krikkit
    21 Jan 2003
    If you like nice peripherals, have a look at them.
    Personally I was interested as soon as I heard about them, but once I pushed that first switch... Oh my. I'm an utter convert now - there's no way I'll suffer a rubber-dome again. No way.
    rollo: I can see what you're getting at, but with the various switch choices available there's something for everyone. A board with reds or blacks are well respected for gaming. Blues aren't ideal, I'll grant you, but browns work very well too.
  20. longweight
    7 May 2011
    This is not true at all.
