Scratch Build – Complete ⭐ The Iron Turnip--6-2019-complete. final pictures on page 29
Discussion in 'Project Logs' started by Cheapskate, 18 Jul 2014.
  1. Cheapskate
    13 May 2007
    This project is brought to you in collaboration with the following companies
    Mod Zoo Munky PC Case badge designed by Cheapskate!
    http://mnpctech.com/pc-case-badges-en/mod-zoo-munky-case-badge.html
    I have been threatening to do a salvage build for some time now. I've lost track of how many times I was asked why I was named "cheapskate." I swear! Do a few high-budget builds, and everyone forgets the cardboard bear.
    Sadly, my stockpile of old denim that I had saved for "ghetto carbon fiber" disappeared when I wasn't looking, so I will resort to metals. I have a fair amount of stainless steel thingamabobs, and lots of aluminum. It's quite possible everything including the kitchen sink will be used, (as I have at least five of those at the moment.)
    The plan this time around is just to use as much junk as possible. The first option will always come from my garage, or my attic, or the woods behind the subdivision.
    There's going to be hammering too!:D I love to beat the sh*t out of stuff with hammers. This will be a very therapeutic project.
    -I settled on this sucker for my primary container. I'm hoping to chop it down as much as possible. This is an old stainless steel soda syrup container. I'm sure anyone who follows me knows I pick up weird stuff from vacant houses. It's unbelievable what you find sometimes, and you have to wonder what they were smoking to steal/keep one of these.
    -Wait, I kept it... What was I smoking?
    -The first thing that had to happen was the heavy rubber end had to come off. I wanted something vaguely BOMB-like for the look, and that squared tail wasn't working. I had to sharpen the chisel anyway, so some heavy rubber chipping happened.
    -I made a glorious mess.:D The pliers were because I found the rubber could be torn easier than it could be cut.
    -I had to switch to a rasp closer to the metal.
    -After an attack with the sander, I found metal. As soon as I saw that seam I was worried it would look like a thingy. I appropriated a few aluminum pans for possible re-cladding.
    - I have to get inside somehow, so I chopped the top off. Here I've hack sawed a start just above the top weld seam. This promptly went outside as it was already smelling like a drag race.
    For using the jig saw, I made the mistake of sitting on the tank to keep it steady. .01 seconds of ultrasonic vibrations to my nethers later, I decided that was a bad idea. I also had to explain that the exclamation I made wasn't because I had cut myself to everyone in earshot. I did NOT tell them why I suddenly did a Rob Halford impersonation, though.
    -This shot should have captured the white smoke of burning rubber wafting out of the tank. It didn't.:(
    -It looks like I can fit a 650W power supply barely. I might look into small form factor power instead.
    -There was some flower arranging, only with computer parts. I decided the radiator I had laying around was too big, so that's the first item I didn't get to use salvage for.
    -I resorted to a cardboard mockup of a 2 x 140 radiator. I think I'll center two 120mm fans on that.
    -Say hello to restaurant heat shield. Apparently, If enough people drop a part because it's hot, the welds on the shield break, and someone throws it away.:D It said it was hot. You would think they would know better with that big warning on it. A small eternity after this pic was taken, I drilled through the stainless steel rivets to remove the sign. -Tough little b*stards!:(
    -A little SMACKIN' with a ball-peen sledge, and it matches nicely. Big rubber doormats make a good anvil. I have a bit of microwave surround in the pic for possible use too.
    -I drew up a fan hole and sawed. -and sawed. -and SAWED. Did I mention cutting the top off earlier dulled a NEW jig saw blade? I resorted to a hack saw since it was much quieter than ringing this big metal drum with a power tool.
    -No, that's not a reference to my earlier junk oscillation.
    -It took forever to dremel a start hole in the flat cuts. I had to use one of these horrible things: a hack saw blade holder. It's amazing how many times you can bend a blade without it breaking.
    -Like this, I can have the radiator flush against the inside wall, and have more room for other stuff. Bending was done with a really big crescent wrench.
    -Here's the other reason to use only 120mm fans: They fit the heat shield perfectly. :D With a little slap, she fit and stayed in place with a friction fit.
    -That's where I'm at now. I have nothing lined up for hardware, and only a vague fuzzy feeling about where I'm going with the design. I gotta make stuff FIT first. Looks come after.
    ifohancroft and kpmodding_ like this.
  2. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Now this I've gotta see. Nothing like a true ghetto/junk/recycling project to keep you going. Bonus is unlike with Glassgween, I'll actually have proof 4 years down the line that I was there from the beginning :p
    ifohancroft likes this.
  3. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Da na na na Da na na na Da na na na SCRAPMAN!!!
  4. Nexxo
    23 Oct 2001
    And his sidekick GHETTO BOY!!! :rock:
  5. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Tales of your personal sybian in the first post, this is gonna be fun :D
  6. supermonkey
    supermonkey Deal with it
    14 Apr 2004
    Fixed it for you. :D
  7. Cheapskate
    13 May 2007
    :lol:
    I entertain you. You entertain me.
    @ Meelobee - I shouldn't have googled that word.:blah:
    @Nexxo -My sidekick for this ride will be Mr.Smashie, the demolition hammer.
    @Maki -This could be a much shorter log, since the finish will be sub-standard.
  8. AlderonnX
    AlderonnX Minimodder
    10 May 2012
    Ah, this I gotta see
  9. Cheapskate
    13 May 2007
    :D Thanks.
    I forgot to mention I will not settle for wood, MDF, or cardboard. -That would be too easy. I'm also going to avoid using plain steel.
    The current plan is to mount the fans to the tank, and have the rest as a slide out module. I would like to hack the tank down to at least 12", but it all depends on the parts fitting.
  10. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Seriously you always come up with the strangest ideas. Love it!
  11. KidMod-Southpaw
    28 Sep 2010
    The interior layout, and, actually, the whole thing reminds me of a dirtied up Mac pro. :D
    I look forward to more!
  12. Cheapskate
    13 May 2007
    @Hukkel - PARTS? -or ideas.:lol:
    @Kid - water cooled too.:D It should look like a gasoline-powered sex toy when I'm done, so yeah, totally Mac-like.;)
  13. leonetu
    leonetu What's a Dremel?
    29 Oct 2013
    Strange - is always good in design. Subbed!
  14. Cheapskate
    13 May 2007
    Right? Boxes start to suck after a while.:lol:
  15. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    I almost spit out my nilla wafers lol.
  16. Lystfiskern
    Lystfiskern What's a Dremel?
    22 Aug 2014
    This thing just might get crazy weird folks...strap on!
  17. Bad Fenny
    Bad Fenny What's a Dremel?
    20 Aug 2014
    Great build . . . my favorite recipe . . . take a bunch of cast off junk, add computer parts, ingenuity and creativty and you get a computer.
    Cheers
    Fen
  18. Jumeira_Johnny
    Jumeira_Johnny 16032 - High plains drifter
    13 Nov 2004
    I have a box of a variety of old pants. If you want me to, I can send it to you.
  19. Meelobee
    5 Nov 2003
    See I wasn't that far off with the Sybian ;) :D
  20. Cheapskate
    13 May 2007
    Sorry about delays. I'm in home repair limbo.
    @Meelobee -no:lol:
    @Jumeira Johnny -No again.
    @Bad Fenny -You forgot, "mix with hammer."
    @Lystfiskern - No again!:lol:
    @Furball - Rats. Almost doesn't count.
