#141 | ||
Is a cackling Yuletide Belgian
"Na'ir" rhymes with far, but it's not exactly that, there's a different vowel before the 'r'. Sort of like an very quick 'i/e' sound. NAA-er would come closest, I suppose. "Al" rhymes with 'cull' (as in controlling herd populations of animals). "Saif" has the same "ai" sound as 'lair', with 's' and 'f' pronounced normally.
__________________
My Flickr
#142 |
Califragilistsic Expialidocious
Na'ir Al Saif = sounds Arabic to me..IDK what it means though
but I would say that this project is Mumtaz / Jayyid Jiddan ya Akhi! ![]() I previously worked in some Aerospace companies- some tech guys there probably would hail you for creating this turbine cowling look-alike fan..heheh |
#143 |
Modding all the Time
I just noticed this project log.Awesome!!!You are very skilled and you must have very much patience to do that details work.Keep it up.
#144 |
Food Maestro.
the Bright One of the Sword
#145 |
Multimodder
This mod is simply astounding at all levels. Your craftsmanship with general hand tools is unbelievable.
#146 |
↓ Don't trust that face!
You assume there will be a left side.
You're not thinking crazy/awesome enough there, stonedsurd.
__________________
#147 | ||
__________________
My Flickr
#148 |
Supermodder
If you don't want to trim the fan blades, you could feed a coping saw blade through and remove the inner circle, then use the drum sander to flatten the nubs left behind, to make it effectively a single ring, rather than two connected rings.
Unless, of course, that is the kind of look you are going for.
__________________
Robert "Anakha" Johnston Going to Canada on Nov 28th! I'm going home! |
#149 |
I'm Squidward
youre such a jerk for being so amazing that it makes me feel incompetent.
__________________
"...clearly poop is not nutritious and it tastes bad." -Bindibadgi "Get off... my... property!" -Clint Eastman, in Grand Tornado |
#150 |
Bit-tech
@oldnewby: I love your idea HDD VGA, can i make like that?
#151 |
still thinking....
Thanks a lot guys.
I like to pronounce the name as: Na-ear al Say-eef, it looked very mysterious and exotic when I first saw it and is a lot better than Iota Orionis. However, it's the translation from Arabic to English that interested me as far as the name was concerned: "bright one of the sword". If anyone can make use of any ideas or methods in this log, then please, take what you like. ![]() The fan carrier was drilled/tapped and bolted to the lower main support. A piece of 3mm angle was to be used to tie the front and back together, but I remembered a couple of pieces of plex I had left over from CX1. These are 20 x 50mm. ![]() ![]() ![]() The fan carrier was made a bit more interesting ( and will be some more) by removing some material at the top. ![]() And I'm quietly smiling at the progress. ![]() ![]() ![]() ![]() ![]() ![]() ![]() The next job, and probably the last to involve thicker material, is to make the support struts. ![]() ![]() These will be cut from some 12 x 40mm bar. I'm not sure about the final shape for the pads, and the only disadvantage to this design is the extra 70mm added to the height of the chassis. ![]() But I've run out of time today. Back soon.
__________________
stillthinking |
#152 |
gief cake?
i almost cant wait man! this is my favorite mod at the moment! its just amazing to see you do that work, and watch the project unfold!
keep up the good work! you impress me more and more with every update!
__________________
#153 |
Supermodder
Great work....and fast, too!
I look forward to the next update. |
#154 |
EvE Addict
extremely well crafted, you've definately got a gift with this kind of work, big fan!
__________________
|i5 2500K| |P8P67| |8GB DDR3| |GTX 580| |Corsair F3 120 SSD| |
#155 | |
Now... with more CNC!
Consistently amazing!
__________________
#156 |
Allons-y!
I really like how that thick plexi looks.
Everything else too, but that's a given.
__________________
AMD Phenom X4 9650 [2.7GHz] | Nvidia GeForce GTX 560ti | 4GB GSKILL DDR2 800 | Gigabyte GA-MA780G-UD3H
______________________________________ Zotac ION-ITX-A-U | 2GB A-Data DDR2 800 |
#157 |
Multimodder
It has Plexi that was used in Cygnus X-1, it is officially the little brother of the coolest case around now :P
#158 | |
Little? Ain't nothin' little about this baby
__________________
My Flickr
#159 |
Billet porn!
![]() "you must spread some rep around befor you give to Oldnewby." :grrr: Someone else rep bomb the man for me!!!
__________________
#160 |
I'm Squidward
you sir are amazing!
__________________
| Tags |
| aluminium, oldnewby |
| Thread Tools | |
| View Mode | |
