#1 |
Squid
REDELUX (18/1 Final pictures and video)
![]() Hi guys. This is REDELUX, the all-in-one version of my arcade machine "R-Kaid-6". Iīm making this for a German friend. For those whoīve missed out on the original machine, hereīs a link Ok, so the original was nice... Buuuuuut not enough. Hereīs the REDELUX: Integrated beamer Integrated sound system Two wireless joysticks and trackball A new and improved custom made MAME frontend New frontpanel The machine will have the same shape and measurements as its predecessor. Iīll focus the log on the new stufz and try not to bore you with the same-same seen before. Hope youīll enjoy it, I know I will / Quizz ![]() ![]() ![]() Edit: This is one of the final pictures, more can be found on page 6 of this thread. ![]() And hereīs a video, if youīre interested in how it actually works: Last edited by quizz_kid; 11th Feb 2013 at 16:30. |
#2 |
Squid
And hereīs the hardware:
A very small 120w PSU ![]() A very ugly Dell Optiplex gx260, stuck(!) in its metal housing. With a 512GB itīll do just fine ![]() ![]() An old 120GB disk and the sound system ![]() This is the Dell M110, a small LED projector. This little fella is surprisingly good, with 300 ANSI and very low heat generation. Since it will be integrated within the console, Iīll only use the remote. But the IR-sensor sits on the back, so to get it up front I had to come up with something. I decided to try a fiber cable for extension of the sensor and it worked! Glad I didnīt had to solder in there. ![]() ![]()
#3 |
Telephasic Mongoose
Subbed. I like the cut of your jib.
__________________
Dreams are the subconscious mind's way of reminding people to go to school naked, and have all their teeth fall out. |
#4 |
The modding head is firmly back on.
Oh yeah, i'm all eyes
#5 |
Keep calm & mod on. =)
Awesome
new quizz project. ![]()
#6 |
Squid
Thanks guys!
For starters, this is my idea of the wireless trackball. Since there are no of such kind on the market I had to go all DIY on this. I bought a cheap long range wireless mouse and took it apart. The trackball housing I had laying around from an older project of mine. ![]() And THIS is the beautiful 51mm Tiger Eye chatoyant. It will suit the walnut very well IMO. ![]() And then I did some wood working Six sides, cut and milled ![]() ![]() ![]() I donīt know if itīs bad gluing or bad veneer, but it cracked at a few spots. I will try to fix it... or hide it somehow. ![]() Hexagon under pressure ![]() This is the feet of the foot stand. Because of the choice of output selection, monitor or beamer, this console will have to be moved around in the room. So I added some small brass wheels. I had to cut off the fittings because they were to big, but it was hard to find a replacement. The holes are 6.7mm and thereīs no (standard)pegs in that size. I used a silicone tube over a M6, and it worked. ![]() ![]() ![]() ![]() The front: ![]() The hole to the right is for the beamer which will be vertically adjustable from underneath. More about that later. ![]() Here are a nice brass fitting for the beamer and the startbutton. ![]() I needed a thin piece of walnut for the back of the brass fitting and glued four veneer pieces together. ![]() ![]() The biggest crack was on the front, and when I tried fixing it it just went worse... ![]() This is one way of hiding it. What do you guys think about it? Too much bling maybe? ![]() ![]() Well, so long! ![]() ![]()
#7 |
I was pretty tempted to buy 1 of those tiger eye rock marbles will make for a very awesome trackball & like you said will go with the walnut nicely, I really look forward to feeling confident enough to make my own custom peripherals like that, sweet modding quiz. ![]() Maybe a simple brass plaque engraved would look better to cover the imperfection but I bet you could make that fit in place, it does look quite nice with the walnut, or a nice little simple pattern made from a different tone of veneer laid on top of the walnut. Just quick thoughts, not suggestions.
#8 |
Supermodder
good to see you on another projekt quizz, good luck!
__________________
Works as a tool retailer, glad if i can help someone with tool questions! Hopes that i someday completes my first scratchbuild... |
#9 | |
Squid
Thanks Kelmannen! Ok, a small update: Started on the controllers. This is the idea: The 1st player left part (where the joystick is) will be detachable from the rest of the pad, and the trackball can be docked right into it. More about that later. ![]() ![]() ![]() ![]() And this is what I did to cover the cracks on the side panels. 4mm walnut frames ![]() ![]()
#10 |
modeteer
excellent solution man, the frames add a bit of depth to the face while also fixing the problem! And that marble is gorgeous as others have said!
I'm excited to see what you come up with for the track ball. I've had a similar idea myself for the past few years but I never took the time to actually try and make it. Hopefully you have some success! |
#11 | |
Squid
#12 |
Squid
Todays work:
There was some minor cracks on the backside, so I made a fan grill to hide 'em. Itīs a hexagon!! Will use brass pegs later ![]() ![]() Also made the fan grill for the frontpanel. ![]() ![]() Some more work on the controllers. ![]() ... and the top piece is almost done ![]() ![]() Will take some days off now... Be back next week! YAY!!
#13 |
Squid
While waiting for some hardware I thought Iīd maybe share another R-Kaid-6 product. Itīs not as complex as the REDELUX, but it has some smart solutions to it. Itīs a 4-player version, with wing doors hiding some of the electronics. Iīve changed the coiled cables for cotton sleeved ones. But what Iīm most proud of is my locking mechanism. Hope youīll like it! / Quizz
Doors closed, controllers on top ![]() Doors opening ![]() Expose of the inner panel ![]() With the four controllers ![]() 3 m Cotton sleeved cables. ![]() Close up ![]() Linked cables ![]() ![]() Backside/table top decoration ![]() This is the locking device. Itīs a small walnut knob hidden under the chassis. It locks/keeps the doors in place by turning the knob in one direction. When turning it the opposite direction, it gives the door a slight push to get them wide open. Iīm very proud about it ![]() ![]()
#14 |
Retro Fan
Oh man, it's another one of your beautiful wooden consoles. It reminds me of a pong console;
It's got sound built in, doesn't use cartridges and it's all wooden =p But seriously this is ace work as usual.
__________________
~Intel Core I3 3220 ~8GB Corsair Vengeance 1600Mhz~ CorsairCX600w ~ Asus GTX560ti Direct CUII Core @ 950Mhz Memory @ 2250Mhz ~ P8H77 ~ 128GB Samsung 830 SSD ~ Gelid Tranquillo ~ USB modded NES, Master System, Mega Drive and N64 controllers for Emulation~
#15 |
Squid
Thank you friend! I actually got a chance to play the original Pong cabinet this summer, itīs such a beauty...
#16 |
Nice solution with the frames.
![]() And wowzers you've been busy creating when did you do the new 4 player one with nifty lock, very nice & tidy. |
#17 |
Hypermodder
Looking great! Can I ask how you cut the holes in the walnut frame that had the chipping? I was just curious if a spiral router bit with the correct direction (up or down, depending on which way you had it) would work better
__________________
Mosquito Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC |
#18 | |
Squid
![]() Thanx! If yore referring to the holes on the hexagon I used straight bits... I have no spiral ones, but I might buy one and try it out. But I think it was a combination of dry veneer and bad gluing this time. |
#19 |
Hypermodder
yeah, the holes in the hexagon, I'm a little behind
Just a thought for something to try. I have a few down and up cut spiral bits, depending on whether I'm using them in my router table, or hand held, and which surface I have the router against. They seem to cut a little smoother, and leave a little cleaner edge for me.
__________________
#20 |
Fenrir The Wolf
Awesome woodworking. Looks really nice.
__________________
Cosmos S Reaper L.R.E.C. Scorpio Arya-under construction ROG Crawler-under construction |
| Thread Tools | |
| View Mode | |
