Case Mod - In Progress ZdMods | Project 720 | Started on the top - Oct 17
Discussion in 'Project Logs' started by Meelobee, 12 Dec 2013.
  1. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Hello again :)
    Now that I've finished Project 180 I've started a new build which I'd like to share with you :)
    The victim this time is a Dell XPS 720. An all aluminum case (3mm) and in my opinion one of the best looking cases ever. I've spend quite some time looking for a good undamaged one, and about half a year ago one was offered on a Dutch marketplace and after some emails and a drive to The Hague I picked up the case. The previous owner removed most of the hardware so it was just the case, perfect for my modding needs!
    Some of the remaining hardware, the cpu heatsink and some ducting
    It's a big case, Project 180 fits inside it, the radiator is a EK-XT360
    Without plastic front
    First thing I did was strip the case. Went quite fast because the case doesn't have an internal chassis, it's just the front and back panel that hold the whole case together. So it was a matter of drilling out some rivets to take apart the entire case
    Because Dell made the case as a BTX the orientation of the I/O panel is upside down and has to be replaced. On the left the original backside and the front on the right
    I've replaced the front and back by 3mm aluminum panels and attached those to the original brackets on the top and bottom
    Up next, het openingmechanism on the sidepanels!
    On the original case the left panel is fixed to the top and bottom and can't be opened. This is a problem because I want to be able to reach the backside of the mobotray, so it needs to be changed.
    On the right panel there is a big metal bracket with the opening mechanism on it, this makes the panel click into the top and midplate of the case. Because I'm not going keep the midplate that part of the opening mechanism isn't needed and can be removed from the right panel and I can use it for the left panel. (On the picture this part is already removed)
    The metalbracket was glued to the panel with some sort of ubertape, almost impossible to remove, but using a heatgun and a putty knive I got it removed
    I've cut the bracket into 2 pieces, the lower one already has an alu strip that will be used as the handle to open the panel
    That's it for now :)
  2. NJB Mods
    NJB Mods What's a Dremel?
    18 Oct 2013
    Can't wait for the result!
    Keep it up mate!
  3. Primum Agmen
    Primum Agmen What's a Dremel?
    21 Sep 2012
    I'll admit I'd never heard of that case, but it looks great. Curious to see what you're going to do with it.
  4. Meelobee
    5 Nov 2003
    Cheers guys :)
    On with the show!
    The bracket was cut in two and I've glued back onto both sidepanels with epoxy
    Glued an chairprofile (I suppose it's what you call it in English) to the bottom side of the left panel
    The profile hooks on the original brackets on the bottom of the case
    And now it looks like I'm back to where I started. The case looks stock again, except this one has sidepanels that both can be opened :clap:
    Up next, the front of the case!
    first I gutted the plastic front panel and removed all the unneeded parts
    Then 8 pieces of U-profile (13x13mm od) where cut to size
    The u-profiles were glued to a strip of alu with epoxy. There is a 6mm gap between each profile
    Both ends of each profile filed to an angle, so the profiles fit perfectly in the front
    And this is how the whole assembly looks in the front. 2 Smaller pieces of u-profile that fill the gaps will be added on both sides
    To finish the front I got some 10x10mm plexi rod
    The plexi fits perfectly in the u-profiles
    The plexi will be frosted and have leds in the top and bottom, but how exactly is in the next update! :p
    Thanks for watching! :dremel:
  5. The_Crapman
    5 Dec 2011
    Awesome. There were absolutely TONNES of these cases around codies when i worked there and always thought they were a perfect blank canvas for some modding. Glad you've taken one up as i've loved pretty much everything else you've done. Looking forward to this progressing.
  6. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    I'm liking where this going. I always loved the look of the older xps cases, so I'm excited to finally see one being modded!
  7. SiZZiGY
    SiZZiGY Nano Evolution in progress...
    11 Oct 2013
    Love this case :naughty: Very nice choice :D
  8. hero1
    hero1 Minimodder
    18 Oct 2013
    hmmm..nice stuff! Subbed!
  9. whyte
    whyte What's a Dremel?
    27 Mar 2012
    good lord.. always impressive. so happy youre starting another build now that 180 is finished :)
  10. MeddlE
    MeddlE Norwegian Blue
    23 May 2011
    Here we go again (in a good way).
  11. Ianovski
    Ianovski Rawr!
    10 Mar 2011
    Love your previous mods so let's follow this one too! Love the idea for the front, curious how it'll work out.
  12. Asouter
    Asouter --------
    18 Jan 2012
    Nice old case, I'm looking forward to seeing this progress :) subbed
  13. Egami
    Egami Why is the dremel on fire?
    27 Aug 2013
    Looks like everyone's again seen the case and knows what it is except for me lol. :hehe: Well, couldn't have hoped for a better modder to take it and start baking! Totally subbed! :thumb:
  14. GamerIDGoesHere
    GamerIDGoesHere www.^.com
    3 May 2012
    There's a lot of potential with that case :thumb:. Got a colour scheme in mind?
    Also subbed :)
    - Dan
  15. Meelobee
    5 Nov 2003
    On with the show!
    Continued on the front. Added 2 shorter pieces to the rest of the U-Profiles to complete the front. All profiles are filed to size (Which was a pain in the ass job, as the corners are round and at an angle.)
    On the top the alu profiles fit align perfectly to the plastic front.
    On the bottom there are some small gaps between the alu and plastic, but this won't be visible in the end. The plexi bars in the profiles are cut short, so there is room for the leds
    Made a logo for the front of the case. The 2 small bars above and below the text will be the same color as the plastic edge they align with. Giving the front 2 'sections' again.
    And I've cut the hole for the 3 radfans in the front (360 rad)
    In the case without the front
    And with front
  16. Zsolt Guriga
    Zsolt Guriga What's a Dremel?
    20 May 2012
    Very clean work :thumb:,looking forward to see:)
  17. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Those XPS cases...the only valid reason to own a Dell.
    Jesse had great results with Plastidip and that case
  18. imersa
    imersa Parvum Princess
    9 Apr 2009
    Lovely thus far.
  19. bulldogjeff
    2 Mar 2010
    Agreed, i remember seeing then and liking the case and thinking it's a case with great potential, going to be watching this one, it's off to a great start.:clap::clap:
  20. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    In as well.
