So now its time for a brand new casebuild This time with a Hellraiser theme. This case will be my servercase and will contain an old P4 1,7 The case vill be an engraved plexicube. The idea is to make an all black and gold cube, to do this i will dremel all the patters and then fill them with leafgold and top it off with sunblock film on the inside. The cube will remain black and gold until the lights switch on. Then the internals will be visible. The mainboard will be mounted with all connecters facing down this will be done so that i can hide all the cables in the wodden base. The cdrom and diskdrive will also be stealthed into the base so that the plexicube itself will remain untouched. I didnt want to cut any holes in the cube since i feel that it would mess up the clean look im going for the only holes will be for 2x80mm casefans one in the front and one at the back. Ive made some sketchup drawings to show yall what i had in mind So now on to the actual build, first some plexi Then some sketching, this will take forever to do with the old dremel but ill get there Ill be back with more soon
did you draw those markings on the plexi??? damn man, if you did, then you are the most persisting one ive ever known
Make sure you are careful, Polycarbonate is strong, but scratches VERY easily... By the way, those are some killer drawing skills...can't wait to see this etched!!
you must not have seen his "demon" project http://forums.bit-tech.net/showthread.php?t=46844&highlight=blacklight+demons i don't think i have ever seen better dremel work, Wolverines skills is past the best @ Wolverine, plans look good will be following this one
wow.... that looks like it'll be good.. although i have seen a hellraiser puzzlebox mod before.. it was actually the mod taht got me into this 'scene'.... let me find a link...... http://www.sheff.com/projects/HellRaiser/hellraiser01.html wow this is old... now that i think about it (i totally forgot about it) i wanna make a small cube case... lol...
At it again are we? looking good! Loved the Blacklight demons case, I'll be subscribing to this one for sure!
Wow, that's one of the most interesting concept I've ever seen! Not sure how you plan to connect cables to the i/o ports on the mobo as they're facing the bottom but I'm sure you already thought about that. Good luck with the dremel
this is going to turn out great just as your last project! looking forward to see the engravings. you're the engraving guru, so this just have to turn out amazing! good luck pal! have fun, go mad
saw pictures of this one just a few days ago but i must say that it's still one of the most impressing cases i have ever seen! you, my good sir, have awsome dremel madskills and i know this case will be a hell of a kickass-m0d when it's done WOLVERINE is our very own Swedish superstar i sure will follow this project, you mod on !
-=Update=- So now im back again Ive been working hard theese last couple of days and what ive been up to you can see here Ive finished 2 sides of the cube, not completely but ive got all the basic etching done and heres how it looks. And the work continues....
Amazing work as always mate! you said one of the colors is going to be gold, have you god gold leds or are you going to paint the parts gold? EDIT: never mind, I'm retarded
