Build Advice £350 gaming build
Discussion in 'Hardware' started by legendzarr, 2 Jan 2013.
  1. legendzarr
    legendzarr What's a Dremel?
    30 Dec 2011
  2. fuus
    fuus Misses Rep Bombs
    4 Dec 2010
    I would agree with everything BUT the CPU / MOBO. I personally would go with an intel CPU combination!
    EDIT: an extra £40, however a much better CPU http://pcpartpicker.com/uk/p/vtRG
  3. Bogomip
    Bogomip ... Yo Momma
    15 Jun 2002
    Im not sure how good that graphics card on there is, but have you considered one of the APUs by AMD? I have a 3870k which is last gen, but its really good and wasnt that expensive (CPU + GPU combined was £90).
    I recently put in another cheap GFX card crossfired and got double the performance again.
    edit: fuus - an extra £40 is extra money! people on this forum suck at budget! :)
  4. legendzarr
    30 Dec 2011
    are you sure about the mobo? seems a bit cheap compared to the cpu
  5. fuus
    4 Dec 2010
    It's a cheap budget so I went for cheap mobo, if you had more to spend I would next spend it on a slightly better mobo :)
  6. legendzarr
    30 Dec 2011
    okay, thanks a bunch!
    fuus likes this.
  7. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
