Motherboards £80 am3 motherboard
Discussion in 'Hardware' started by D-NO86, 26 Sep 2010.
  1. D-NO86
    D-NO86 What's a Dremel?
    3 Jul 2008
    im building a new am3 system looking to spend up to £80 on a motherboard to pair with a phenom II 4x 955 or phenom II x2 555
    system will be used for gaming and some overclocking
    im currently looking at the ASUS M4A785TD-M EVO you gave it a very good review but its over a year old
    any suggestions?
    edit: the board has to be MATX
  2. Guest-16
    Guest-16 Guest
    That's still a great board. Either that or the Gigabyte 880G on the front page right now, the only difference being the upgraded southbridge which isn't much to be honest - don't be fooled by the '880' vs '785' - AMD uses the same core underneath.
    The ASUS EVO's have more power hardware for overclocking, which is better suited if you're cranking that Phenom II up a lot :thumb:
  3. D-NO86
    3 Jul 2008
    thanks :cooldude:
