Build Advice £800 film editing pc
Discussion in 'Hardware' started by Birdy, 10 Apr 2011.
  1. Birdy
    Birdy What's a Dremel?
    13 Jan 2011
    IT WORKS! YAY! :D
    I guess I shouldn't be surprised though...
    So thanks very much to everyone who helped me choosing stuff for it.
    + scan didn't have the antec 100 in stock when I ordered so its in a Silverstone precision pb02 since it was the old CPC budget case.
    My only thought now is the amount of noise it makes - do you think that it would help more if I replaced the (one) case fan for a lower rpm one since I have a non OC cpu, or should I try replacing the intel stock cooler. If so, what do people recommend?
  2. jamsand
    jamsand Minimodder
    21 May 2011
    scythe shuriken very quiet and good for stock or mild overclock if you ever wanna try it put it on a friend pc when was building his.
    and yes I'd say replace the stock fan
    Enermax TB silence batwing one for front one for the back that way you can run them at lower speeds(if your motherboard has pwm pins that'd help:))
  3. donok
    donok Every Little Helps .....
    16 Feb 2011
    you could get some sound dampening foam stuff and line the inside of the case with it
