POTM [06/07] Static Motion
Discussion in 'Photography, Art & Design' started by yodasarmpit, 22 Jun 2007.
  1. yodasarmpit
    yodasarmpit Modder
    27 May 2002
  2. Amon
    Amon inch-perfect
    1 Jun 2007
    Looks good enough to be in a FIAT brochure. j/k
    Is that a Fiat?
  3. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Toyota.
  4. Krikkit
    21 Jan 2003
    Nice shot - did you mount the cam, or get someone very brave to hold it? Only problem I can see is that dodgy line on the paintwork (be it reflection or what), just above the black trim. :)
    What tyres have you got on there? They look a bit like Mich Pilot's.
  5. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    I had the cam attached to a tripod extended out the passenger window, composed the shot and got back in the car, start to pull away whilst holding the tripod steady with my left hand and pressing the shutter button on the remote switch at the same time :D
    It's Dunlop SP Sport01's on the front atm, pretty decent in the wet.
    I should have polished the car first :)
  6. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    awesome shot!!!:thumb:
  7. Krikkit
    21 Jan 2003
    Nice thinking - must've been a carefully planned thing then. :p
    The Sport01's look pretty good tbh, not as nice as Toyo Proxie's or GDS3's, but there we are. :)
  8. Cptn-Inafinus
    Cptn-Inafinus Minimodder
    3 Mar 2007
    Good job, the composition in this are lovely.
    And purely out of curiosity, what are those window mount tripods like. Are they actually any good?
  9. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    I have no idea, I just used a regular tripod.
  10. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Toyo proxies are good on the MR2's, lots of grip from the rears which is important.
  11. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    probably what ill be putting on it next.
  12. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    Continueing on this off-topic route. Goodyear Eagle F1's are supposed to be considerably better than Toyo Proxies in the wet.
  13. Havok154
    Havok154 What's a Dremel?
    20 Aug 2006
    I really like that. Good job.
  14. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    Looks swish just a lil confused, what is that in the top left in black, looks like sky but it surely can't be night...
    None the less, a great shot :thumb:
  15. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    It's a small forest of trees.
  16. OleJ
    OleJ Me!
    1 Jul 2007
    Great colors! Just as Nath I was intrigued by the dark areas. They really make the rest stand out almost like neon. Plus you've got motion blur in the tire as well as radial blur... Brilliant. (Don't tell Nath, but I think this one is better :p )
  17. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Thanks OleJ, I won't tell Nath :)
