POTM [08/07] - French Fade
Discussion in 'Photography, Art & Design' started by GuardianStorm, 20 Aug 2007.
  1. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    I took this picture while on holiday in Canada, it only has a little post processing done to it:
    EXIF:
    Filename : POTM_1_FULL.jpg
    JFIF_APP1 : Exif
    Main Information
    Make : EASTMAN KODAK COMPANY
    Model : KODAK Z740 ZOOM DIGITAL CAMERA
    Orientation : left-hand side
    XResolution : 230/1
    YResolution : 230/1
    ResolutionUnit : Inch
    YCbCrPositioning : centered
    ExifInfoOffset : 180
    Sub Information
    ExposureTime : 1/350Sec
    FNumber : F2.8
    ExposureProgram : Program Normal
    ISOSpeedRatings : 80
    ExifVersion : 0221
    DateTimeOriginal : 2004:01:01 14:16:38
    DateTimeDigitized : 2004:01:01 14:16:38
    ComponentConfiguration : YCbCr
    ShutterSpeedValue : 1/362Sec
    ApertureValue : F2.8
    ExposureBiasValue : EV0.0
    MaxApertureValue : F2.8
    MeteringMode : CenterWeightedAverage
    LightSource : Unidentified
    Flash : Not fired(Compulsory)
    FocalLength : 6.30(mm)
    MakerNote : Unknown Format : 2412Bytes (Offset:756)
    FlashPixVersion : 0100
    ColorSpace : sRGB
    ExifImageWidth : 2576
    ExifImageHeight : 1932
    ExifInteroperabilityOffset : 3154
    ExposureIndex : 80/1
    SensingMethod : OneChipColorArea sensor
    FileSource : DSC
    SceneType : A directly photographed image
    CustomRendered : Normal process
    ExposureMode : Auto
    WhiteBalance : Auto
    DigitalZoomRatio : 0/100
    FocalLength(35mm) : 38(mm)
    SceneCaptureType : Standard
    GainControl : None
    Contrast : Normal
    Saturation : Normal
    Sharpness : Normal
    SubjectDistanceRange : Macro
    ExifR98
    ExifR : R98
    Version : 0100
    Thumbnail Information
    Compression : OLDJPEG
    XResolution : 72/1
    YResolution : 72/1
    JPEGInterchangeFormat : 3290
    JPEGInterchangeFormatLength : 4902
  2. lcdguy
    lcdguy Minimodder
    25 May 2004
    where did you holiday at in canada ? Quebec ?
  3. GuardianStorm
    26 Apr 2005
    Yes, kinda, we landed in Toronto, and then went to Niagara Falls, Kingston, and up to Montreal where we are staying (im still here) we also went to Boston, and numerous other places on routes :)
  4. lcdguy
    lcdguy Minimodder
    25 May 2004
    did you stop by in ottawa or did you just continue on to montreal after kingston up the 401 ?
  5. Hugo.B
    Hugo.B What's a Dremel?
    4 May 2007
    All that camera information and you don't even say what's written...
