Windows 1:1 drive drive copier
Discussion in 'Software' started by Sheiken, 17 Nov 2009.
  1. Sheiken
    Sheiken Wat?
    9 Jan 2005
    Hi I have just recieved my new harddisk seeing as my old one died on me, but I have in the meantime used the disk from my external WD mybook, I just dissasembled it.
    Now I have received my new Seagate F3, and I dont want to go through all the hassle of reinstalling everything, is there some software that makes a true 1:1 copy of the disk I'm currently using? Perhaps via USB as I can just pop the new drive in my external enclosure.
    Help will be appreciated!
  2. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
  3. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    i have has good results with clonezilla. it runs as a livecd and allows local and network clone / restore of both whole disks and partitions. also i would leave both disks in the pc connected by sata / ide and pop the drive back into usb after its done since it will write a whole lot faster connected to the onboard disk controller.
  4. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    Another vote for clonezilla.
    When the RMA for my WD Caviar Black 640gb turns up this week it is that tool I shall I attempt to use to copy my data over :)
    I've used it for backups to USB or other drives several times.
    Just make sure - as with any other cloning app - you're totally sure which is the source and the destination!!
  5. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    We use Acronis at work. It's not free though :(
    But of my quick look at the available free ones, CloneZilla looks to be the trick :thumb:
    With most cloning programs, if the F3 is 100% unused (ie not even formatted/partitioned) then the cloning program should automatically select that as the destination drive.
    At least, that's what Ghost and Acronis do by default. Be careful.
  6. Sheiken
    Sheiken Wat?
    9 Jan 2005
    My pc is currently running acronis right now, I'm quite skeptical about how it will turn out, but I hope I am positively surprised hehe
  7. butter100fly
    butter100fly Rebelstar Raider
    16 Sep 2009
    Now I'm only being finicky as it might help.....forgive me
    But a 1:1 drive copier is simply the 'nix command dd
    that will copy your disk bit for bit
    I don't think you want this - there has to be a level of intelligence in a copying tool so that, for instance, if your old and new drives are different sizes or types etc then it will actually work
    1:1 copying is used if you want to put the same contents back on the same drive as before in the same state it was in before....
    is it a valid way of clearing your ssd for trimming though? I would think so as theres no defrag issues etc on an SSD?
  8. NaNeil
    NaNeil What's a Dremel?
    27 Jul 2007
    I used and was very impressed with 'Partition Wizard', it's free :)
  9. Zoon
    12 Mar 2001
    Clonezilla is getting a stack dump error when trying to copy my Windows 7 partitions.
    Dunno if its my PC or if there's something different about Windows 7 partitions that aren't playing well with CZ.
  10. Pookeyhead
    30 Jan 2004
    Norton Ghost 14. All you need for back up and imaging your drive. Create a back-up, swap out your hard drive for the new one, then restore from the back up CD... reboot. It's as if nothing has changed.
    I've used it since version 7 and it's been nothing short of fantastic.
  11. ThunderBob
    ThunderBob What's a Dremel?
    19 Sep 2005
  12. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    Acronis or Ghost
    have used both at work with good results
  13. Gryphon
    Gryphon What's a Dremel?
    24 Apr 2009
    or use a live linux distro that has GParted on it (ubuntu is good) that way you dont have to be using the drive as you're copying from it, which has caused me some problems in the past.
    you can download a bootable version of GParted, but it takes ages to boot... i'd still advise ubuntu.
    otherwise paragon has worked for me.
  14. unknowngamer
    unknowngamer here
    3 Apr 2009
