Electronics 100w Drawing Lightbulb
Discussion in 'Modding' started by M_D_K, 23 Feb 2012.
  1. M_D_K
    M_D_K Modder
    3 Apr 2002
    Hello fellow techers :)
    Got a bit of a pickle at work I need to make a 100W drawing lightbult with a Bayonet fitting, as you can't buy 100W bulbs anymore due to the goverment having a hissy.
    Basicly one of our Press breaks has a light on the front that indicates when the light guards are active and if the bulb breaks the machine wont work until it detects a new 100W lightbulb and has to be 100W, I've got the engineer out but I'm not paying there crazy money to fix the problem so.
    If I got an LED bulb what would I need to cram into it to make it draw the extra say 94w of juice safely :) ?
    All help will be met with cookies of greatness :).
    http://www.ebay.co.uk/itm/LED-Bulb-...9343600?pt=UK_Light_Bulbs&hash=item27c20ccdf0
    Cheap ebay bulb.
  2. dullonien
    dullonien Master of the unfinished.
    22 Dec 2005
    I found 100W bulbs in stock in my local pound shop, and promptly purchased 6 boxes. I use them in my office, because energy saving light-bulbs just don't cut it when you're making intricate models, or drawing. I don't care if energy saving bulbs claim to be 100W equivalents, they simply don't come close.
    So yeah, have a look around, they're still available.
  3. Atomic
    Atomic Gerwaff
    6 May 2002
    You couldn't put 100W through an LED without melting it.
    LED's by design draw a very small amount of current, so without fitting a "big ol' current sucking resistor" you're not going to find what you are after.
    You might be better off looking for a Xenon Halogen Lamp with a bayonet fitting as this will give you the high current draw you're after.
  4. M_D_K
    M_D_K Modder
    3 Apr 2002
    That is exactly what I'm after, how would I wire that into the bulb so that it draws the power?
    I'll take a look at the halogen option as well :).
  5. longweight
    7 May 2011
  6. longweight
    7 May 2011
    Not through one LED no but you could through an LED lamp if they existed in such a high power draw package :p
    I really wouldn't go for Xenon, they have such short lamp life!
  7. Lance
    Lance Ender of discussions.
    6 May 2010
    I've got a load of 100w philips lightbulbs that are energy efficient. They are avaliable.
    Also you could try amazon?
  8. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
  9. Dezzsoke
    Dezzsoke What's a Dremel?
    21 Jun 2011
    Or you could use 2 60watt bulbs, just cut the wire, and connect another bulb parallel.
    since its parallel the machine thinks its 120watt.
  10. M_D_K
    M_D_K Modder
    3 Apr 2002
    According to the engineer its got to be 100w :(, got one old 100w in at the moment but will work on modding an LED lightbulb when it arrives.
  11. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    Have you actually tried a lower wattage bulb? Despite what the engineer says their usually 'fitters' not 'engineers' so when it comes to servicing they replace like for like.
    I had an engineer at my last job throw a fit over the fact we gave him a purple Cat5 patch to replace his broken grey Cat5 cable they use in the field to talk to our devices. Needless to say we gave him a Red cat5 cable and said it was faster.
  12. Dezzsoke
    21 Jun 2011
    there's 60watt bulb, and there's also 40watt bulb, 60+40=100, but i think anything over 100watt will turn the thing on.
  13. Nexxo
    23 Oct 2001
    ^^^ This. I'd think it very strange that the machine sensor would be married to a specific wattage of bulb. I bet it just looks for a closed circuit and any bulb will do.
