Is it true that socket 1151 Xeons will not run on consumer chipset motherboards? I've read stuff saying so, but I haven't seen anything definitive. Can anyone confirm?
From what I recall no, they definitely don't work. They (Intel) changed the chipset after Haswell because they didn't want people buying them for gaming PCs. Shame, because they were a good chunk cheaper usually due to no iGPU.
Yes it is. You need a C-series chipset [C236 for the 1151 ones iirc]. EDIT: Take for instance ASUS' Z270-WS, note how it does not [officially] support any of the xeon offerings... if any of their Z270 boards took a S1151 Xeon, you'd expect the Workstation-aimed board to be it.
FWIW, you *can* iirc, put a regular i3/i5/i7 in the a C236 board [or you can with ASUS']. So tldr - Core i-whatever + Server board [C236] = fine Xeon + Consumer board [based on Z/H270] = sad panda Not sure why you'd want to... but you can...
Yes, s1150 (Haswell/Broadwell) is the last Core ix and Xeon on consumer boards combo. Interestingly, I see that they have cobbled a Coffelake i3 onto a Z270 board - look complicated. 6 Step hack...don't know how some of these people have the time to think up and test this shizzle
