Motherboards 1155 Motherboard upgrade.
Discussion in 'Hardware' started by viewasjack, 17 Aug 2011.
  1. viewasjack
    viewasjack What's a Dremel?
    29 Nov 2010
    Hi guys, here the situation.
    Basically I've had my current Gigabyte P67 UD4 since they were first released in Febuary. Its still the old model with the dodgy SATA ports, so I emailed the company were I purchased it from and they said I can have a refund, replacement upgrade to a B3 version, or pay the difference on a better model.
    What would you guys do? Ive got my eye on a Gigabyte Z68X-UD7 Because I'd only have to pay £150 for it technically. Is there much difference moving between P67 and Z68? I do want to overclock my I52500K too. And the new touch BIOS looks quite nice.
    My rig is in my signature. Thanks for the help!
  2. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Unless you need the extra features that z68 gives you (onboard gpu, smart cache) then the premium isn't worth paying. My dad has an MSI p67a-gd53 and that is just as good as my asus p8p67 for a little less.
  3. Neilc
    Neilc Minimodder
    5 Apr 2011
    Sorry to ask another question but can the Z68 board allow switching between GPU's to save power? because if so I may upgrade as my pc is on all day for work at the moment?
  4. Pookeyhead
    30 Jan 2004
    That WOULD be worth having! Especialy if it automatically switched when no or little GPU power grunt us required.
  5. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    The only Z68 motherboard that showed any better stock performance over P67 boards is the Asus Maximus IV Gene-Z, and no I'm not being a fanboy because I have one. Look at the bit-tech review.
  6. Neilc
    Neilc Minimodder
    5 Apr 2011
    Hell I'll switch it myself with a lil linky on the desktop..
  7. reggie50
    reggie50 Minimodder
    24 Apr 2009
    iirc, the Z68 chipset can switch between the GPUs but it is very iffy. It would only activate the main GPU if there was a directx call, and would use the integrated for everything else regardless of load/performance. Plus it didn't save any power as the main GPU was kept on all the time.
  8. viewasjack
    29 Nov 2010
    I think im just going to take the plunge and grab a UD7. Im upgrading my R3 to a Corsair 650D so its going to look real nice tucked away in one of those. Thanks for the advice anyway guys!
