Memory 12 Gig Ram?????
Discussion in 'Hardware' started by Bugste81, 21 Feb 2012.
  1. Bugste81
    Bugste81 Stephen
    16 Mar 2010
  2. mikeyman198
    mikeyman198 Lets pretend this is hilarious.
    12 May 2011
    The only difference is aesthetics to be honest, the vengence kit has tall heatspreaders and MAY overclock slightly better, but there really isn't any performance boost :)
  3. AoE
    AoE What's a Dremel?
    4 Oct 2011
  4. mikeyman198
    12 May 2011
    Well, he clearly needs a triple channel kit, so those aren't gonna be of much use :thumb:
  5. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    A RAM drive is an area of RAM reserved to be used as storage. So basically, you could make a very small but very fast SSD.
    As RAM is volatile, its only available to use while the PC is on, I presume when you turn the PC off, it writes everything from the RAM drive to the Hard drive.
  6. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    Corsair recently did a write-up on using RAM as a cache drive using software which costs around $80. The numbers were hugely improved in some cases but I dont know whether this would equate to improved real world or "how fast it feels" performance compared to a quick SSD. More info here.
  7. Bugste81
    Bugste81 Stephen
    16 Mar 2010
    Thanks for the Corsair Link. I've had a quick play with the program and it's great. Need to do a bit of tweaking to assign it to my Hard drives as well. The up shot is I've ordered the 12gb Kit of Corsair Vengeance.
  8. Taniniver
    Taniniver Minimodder
    24 Aug 2010
    If you want a classic RAM disk as opposed to that caching system, there are a couple of options I've used.
    Dataram RAMDisk is good in that it allows you to mount the drive automatically on startup, but it's limited to only a 4Gb disk in the free version -
    http://memory.dataram.com/products-and-services/software/ramdisk
    Alternatively I've also been using ImDisk - it isn't as good in terms of features, but for this one there is no limit on the RAM disk size you can create -
    http://www.ltr-data.se/opencode.html/#ImDisk
    Of course, what you can actually DO with a RAM disk is up to you :) I tried copying games to one and playing them from there, but didn't notice significant speedup compared to playing from the regular location, though that was a nice fast SSD to start with.
  9. Bugste81
    Bugste81 Stephen
    16 Mar 2010
    Brilliant. Will give that ago as well. Thanks for the info.
