Electronics 12 volt to 8.5 volt, odd fan
Discussion in 'Modding' started by pingthepiratehobo, 8 Feb 2007.
  1. pingthepiratehobo
    pingthepiratehobo What's a Dremel?
    22 Aug 2005
    i've gotten this 40mm blower fan from a ps2 slimline with the intention of setting up some form of quiet ram cooling, just to keep the air shifting in that area, but the fan requires 8.5 volts. Any simple ways of powering this fan from a 12 volt line? Or am i going to have to make a pcb with several resistors to avoid burning it out?
  2. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    You could give it the old 7 volt trick, but it's probably still going to be louder than an 80mm at the same voltage.
    Worth a shot though, but running it at 12 would have you ripping it out within an hour, it'd scream.
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Forget resistors, just fit a 3.5V-ish zener diode in the fan's 12V positive line. A common 3.6V 1.3W type will cope with fans up to about 350mA. You could use a higher-voltage zener if you want to run the fan at under 8.5V
  4. h_2_o
    h_2_o What's a Dremel?
    24 Jun 2004
    or a simple 7805 inline will put it right near 8v
