Modding 120mm fan duct/guide
Discussion in 'Modding' started by tok3n, 24 Jun 2003.
  1. tok3n
    tok3n What's a Dremel?
    20 Apr 2003
    Has anyone seen angled air guides / ducts for 120mm fans. Would be nice to use one on a top radiator to guide fresh air from the side to it.
  2. zackerouac
    zackerouac bring it
    23 Sep 2002
    1/16" plexi, utility knife, and some glue - viola! :dremel: :D
  3. Clockworks999
    Clockworks999 What's a Dremel?
    20 Jun 2003
    I made my own angled duct to feed air from a front case fan to a Zalman flower cooler. I used 1.5mm (1/16") styrene sheet (Plasticard, from hobby shops). This stuff is very easy to cut with an Exacto, just score and snap. It is also flexible, so you can use single-plane curves in your design.
    Cheers
  4. Nismo G-TR
    Nismo G-TR What's a Dremel?
    1 Jun 2003
    i havent seen 120mm ones but there are 80mm ones. Try making one yourself.
  5. SJP
    SJP What's a Dremel?
    12 Feb 2003
    Maybe this or this would fit the bill?
    They're 100mm across, so should be ideal for 120mm fans.
  6. tok3n
    20 Apr 2003
    Possibly. Although I'm leaning toward just using that clear 80mm fan duct on the side 80mm fan to aim the fresh air to the radiator.
