1st Project: Perspex Cube Case [Update 15/04]
Discussion in 'Project Logs' started by HQ08-Modder, 9 Jan 2004.
  1. HQ08-Modder
    HQ08-Modder What's a Dremel?
    14 Nov 2003
    I've decided to start making my own case, being a first time modder (only a couple of mods under my belt) this will be a difficult task but i don't care, nothing scares me so here goes.
    Ill be building a perspex case with the dimension 75(height)x50(width)x55(depth). It will have to compartments because in the bottem section i will have my waterchiller and the 2 side panels will have hinges as well as the 2 lowers parts of the case front and back. The case will have an aluminum frame which makes it nice and light as i push it up driveway to the final distination... my room. As i build the case the idea will hopefully hit you guys.
    Oh and many inspiration from you guys with your great skills in modding to help me want to do this project so thanks.
  2. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Sounds like a nice and interesting project to be! You got my attention :)
  3. HQ08-Modder
    14 Nov 2003
    Well i started by first making the drive cages which i salvaged from an old case then custom made them to my own satisfaction. I also pulled out a psu bay which i will use.
    So here are some pics.
    Overall pic of all the things i made.
    Here is the spare hard drive bay so in the future if i wanna add another hard drive i can store it in here.
    A shot of the Cd rom Drive Bay and Hard Drive bay rivited together.
    How i put them together, rivits and a drill.
    Oh and finally the psu bay that i salvaged too.
    Next step was to start on the frame.
    Pics uploaded tommorow, as the site im using to hsot the files only allow 5 uplaods a day.
    Also tommorow plan to finsih the frame which hasn't been finsihed yet.
    Edit: Fixed pics
  4. HQ08-Modder
    14 Nov 2003
    Woo hoo support, but dont' expect a magically cool mod. I suck at modding :)
  5. ReFredzRate
    2 Sep 2002
    That doesn't matter. As long as you feel good doing it... I screwed up a few mods, and finished only 2 of them all... So I'm no magician either. But hey, who expected Orac3 to be like this? So you never know what will happen... I'll be keeping my eyes on here... :lol:
  6. HQ08-Modder
    14 Nov 2003
    Anyone got another free host i just wanna use one for pure image hosting.
    Iv'e got some pics of the first bit of construction of the frame.
  7. orb
    orb satisfying.
    23 Dec 2003
  8. dirtbiker
    dirtbiker What's a Dremel?
    24 Dec 2003
    Could be a cool project, i want to do a cube case some day... :)
    Are you using a full size motherboard and drives? :eyebrow:
  9. HQ08-Modder
    14 Nov 2003
    Was just using that one -theBroken
    Anyway,
    Well uploading some more images see if these work.
    Well the first building fo the frame started. I did the bottem sections base.Got some plans too, dont' ahve a scanner wokring so yer.
    First i cut the 2 L piece of alumium to size using a hacksaw then filed them flush. To make the base square i used this peice of wood which was square to put them together.
    http://www.hamlesh.com/~publicgallery/public_gallery/Painting_013
    Once squared i drilled a hole in the corner and rivted them together. I did this to all corners and finished with this result.
    http://www.hamlesh.com/~publicgallery/public_gallery/Painting_012
    You can also see in the pic an alumium bar which will be used to stablise the alumium sheet which i may put over it tommorow.
    To put these bars in i evenly palced them then flipped the base over and drilled holes in the base and bars at the edge to rivit them in. Did this to all 4 bars and come up with this result.
    http://www.hamlesh.com/~publicgallery/public_gallery/Painting_016
    Also here are some plan of the case. I got some more but i need to fix my scanner soon.
    http://www.hamlesh.com/~publicgallery/public_gallery/Painting_015
    Also here are the 2 75cm L peices i cut up. Tommorow ill make the other 2 and finish the basic frame of the case.
    http://www.hamlesh.com/~publicgallery/public_gallery/Painting_019
    Also have some pics of the riviting on the base.
    http://www.hamlesh.com/~publicgallery/public_gallery/Painting_017
    http://www.hamlesh.com/~publicgallery/public_gallery/Painting_018
    LOL i doubt im gonna get any support for this mod, but hey its cool. Also flame all you want if i **** something up.
    Hope this post made some sense, and hope the rest do.
    No for some emotions i feel wanna go :dremel: :duh: :hip: :nono: :rock: on
  10. HQ08-Modder
    14 Nov 2003
    Well be using full size motherbaord and using normal drives.
  11. HQ08-Modder
    14 Nov 2003
    Well some Comp Specs
    Barton 2500+ (Watercooled) @ 2400mhz 1.925v
    Corsair XMS 3200 (2x 256 Twinx) @ 2-2-2-11 2.9v
    HIS Excalibur Radeon 9600 pro
    Western Digital 80gig Hard Drive 8mb Cache
    Antec 480w True Power
    I was thinking of having an on off switch for my fans as they gonna piss me off when i sleep so i picked some swtiches up with these coneectors at the back and im wodnering would they be suitable.
    (Sorry about quality of photo, nto soo great lgihtening and camera)
    [Damn site can't find the photo]
    It basically an on off switch with 2 connectors.
    I was also thinking of making a 12v to 7v controller, but all this will be done near the end of the project.
  12. HQ08-Modder
    14 Nov 2003
    Uggg new site design confusing.
    Anyway today im going to hopefully get some more alu L peices to finish off the frame if i can do it in time. So some pics tonight if i do anything :hip:
  13. HQ08-Modder
    14 Nov 2003
    Plans
    Plans
    Just scanned the plans so enjoy hopefully.
    Heres the actual overview.
    The framework that i will be working on soon.
    Heres what i maaay create for the phase change unit.
    The design of how the esky and phase change unit will work together.
    And the design of the case front.
    And the design of how all the pipings of the watercooling setup will work.
    http://members.optusnet.com.au/jaadam/case_mod/water_works.jpg
  14. Green Soda
    Green Soda What's a Dremel?
    26 Dec 2002
    Im getting a sea of red X's
    If you need bandwidth, send me an email or IM, i can host em for you
  15. HQ08-Modder
    14 Nov 2003
    MMm alright, i just finsihed building the basic frame so yer need some web hosting.
  16. HQ08-Modder
    14 Nov 2003
    Neway this site hopefully keeps the pictures together.
    First off i bought 3 more huge ass alummium L peices.
    So a pic of one of them.
    http://www.hamlesh.com/~publicgallery/public_gallery/Painting_027
    I then cut them into 75cm lengths. Here is a pic of the rough end.
    http://www.hamlesh.com/~publicgallery/public_gallery/Painting_028
    Cut 2 and i now had 4. THe other 2 i cut on the second day of modding.
    http://www.hamlesh.com/~publicgallery/public_gallery/Painting_029
    I then filed the newly cut peices flush.
    http://www.hamlesh.com/~publicgallery/public_gallery/Painting_030
    Next step, attach the peices on the base. I did this by riviting them on the corners.
    http://www.hamlesh.com/~publicgallery/public_gallery/Painting_031
    I did this to all peices and ended up with this result.
    http://www.hamlesh.com/~publicgallery/public_gallery/Painting_032
    Another pic of the finsihed supports.
    http://www.hamlesh.com/~publicgallery/public_gallery/Painting_034
    I then cut up 2x 50cm peices and 2x 55cm peices. Here i rivit the top peices on to the side of the support.
    http://www.hamlesh.com/~publicgallery/public_gallery/Painting_035
    Did it again on the second peice.
    http://www.hamlesh.com/~publicgallery/public_gallery/Painting_036
    Then finsihed it off.
    http://www.hamlesh.com/~publicgallery/public_gallery/Painting_037
    Finsihed basic frame.
    http://www.hamlesh.com/~publicgallery/public_gallery/Painting_038
    Tiped it on its side to show how long it is.
    http://www.hamlesh.com/~publicgallery/public_gallery/Painting_039
    Pic of how big the base is.
    http://www.hamlesh.com/~publicgallery/public_gallery/Painting_040
    And then me being abel to fit inside the case.
    http://www.hamlesh.com/~publicgallery/public_gallery/Painting_041
  17. HQ08-Modder
    14 Nov 2003
    Alright pics fixed. Anyway things to do tommorow
    • Do internal frame
    • Add Hinges
    • Might start putting the perspex in
  18. HQ08-Modder
    14 Nov 2003
    I didn't do much today, just cut some more peices and the bottem front perspex panel.
    Update #5
    Okay jsut before I start, this is why you measure twice.
    I marked the peices then cut 2x 55cm and 2x 50cm.
    The peices edges weren't very good so i need to file them.
    So filed them all and ended up with this result.
    I went searching for an esky for the waterchiller unit, after about 10mins searchign i found this nice esky.
    I put the esky in the case to see if it fits which it did so its perfect.
    Heres the pic with the lid on the esky and not much room since i had only 45cm to work with.
    To fit the base for the motherboard and all i makred where i needed to place the L peices.
    After measuring,drilling,rivting all peices i ended up with this result. Als you can see how close the esky is from the the L peice.
    The 2 rivits holding the 2 of the peices together.
    This is how close the esky is to touching the top.
    Time to cut some perspex.
    So firstly i marked up the perspex with masking tape.
    After one cut using a Black and Decker Scorpion.
    Now a ending pic of the days work.
    Here is a design of my new watercooling setup that i quickly drew up.
    What to do Tommorow:
    • Cut More Perspex Panels
    • Add Hinges (Maybe)
  19. Dragosoft
    Dragosoft What's a Dremel?
    29 Aug 2003
    It's huge! :thumb: Good job, I can't wait new pics :rock:
  20. Jpantoga
    Jpantoga What's a Dremel?
    12 Jan 2004
    nice project, do you have AIM?
