1st Project: Perspex Cube Case [Update 15/04]
Discussion in 'Project Logs' started by HQ08-Modder, 9 Jan 2004.
  1. HQ08-Modder
    HQ08-Modder What's a Dremel?
    14 Nov 2003
    Nah don't use AIm nor ICQ, only msn.
    Today, well ahvnt' done anything. Might start soon, its getitng cooler.
  2. HQ08-Modder
    14 Nov 2003
    Okay guys im pissed off.
    The site i use to host my pics has decided to **** up username. So now i can't login :(
  3. HQ08-Modder
    14 Nov 2003
    Update #6
    Okay Update #6
    Okay, today i did some light work.
    Okay first step, make tray for motherbaord tray.
    So i first cut up a peice a alu to fit the box.
    But the farking thing wouldn't fit.
    http://www.hamlesh.com/~publicgallery/public_gallery/frame_011
    So i put it in my workbeach to be filed.
    http://www.hamlesh.com/~publicgallery/public_gallery/frame_012
    http://www.hamlesh.com/~publicgallery/public_gallery/frame_013
    Which didn't do enough.
    http://www.hamlesh.com/~publicgallery/public_gallery/frame_014
    http://www.hamlesh.com/~publicgallery/public_gallery/frame_015
    So then i thought that wouldn't be enough and hacked it right, then filed it flush.
    http://www.hamlesh.com/~publicgallery/public_gallery/frame_016
    The psu bay didn't seem to hae enough support so i cut a peice to support it and rivited it under the middle bar.
    http://www.hamlesh.com/~publicgallery/public_gallery/frame_017
    I then mounted the esky in and there wasn't very much room left space.
    http://www.hamlesh.com/~publicgallery/public_gallery/frame_018
    I then put the psu bay in and liked what i was seeing but, i need to cut a hole in the bay because my powersupply had an intake fan in the bottem of the psu.
    http://www.hamlesh.com/~publicgallery/public_gallery/frame_019
    So after some marking up, cutting with the jig and then filing i ended up with a nice 80mm square.
    http://www.hamlesh.com/~publicgallery/public_gallery/frame_020
    Tommorow im not sure what im gonna do but tonight Im gonna re do the plans with proper measurements since im getting the perspex panels cut.
  4. HQ08-Modder
    14 Nov 2003
    Update #6
    Okay Update #6
  5. HQ08-Modder
    14 Nov 2003
    Just bought myself a nice Little River White Water Waterblock which should be here in a couple of days.
    http://www.employees.org/~slf/lrwb/
    Also got myself some nice ramsinks and gonna build a dual 60mm airduct tonight out of cardboard (GHETTO ALL TEH WAY TILL ITS NOT NEEDED).
  6. HQ08-Modder
    14 Nov 2003
    Warning 56k
    Update #7
    Alrighties, today i didn't do anything due to me being lazy but tommorwo i Have some plans to order some perspex being cut at a plastic frabitcator.
    Anyway here is some pics i took of my ghetto 60mm fan duct made with cardboard and pvc tape.
    Oh and here are some pics of my designing desk, but set the keybaord up since i was formatting my comp.
    PIC #1
    PIC #2
    Ill re do the duct in excess perspex soon maybe.
  7. dirtbiker
    dirtbiker What's a Dremel?
    24 Dec 2003
    Seem to have a bit of a problem with light levels?!
    The case is coming along nicely though, can't wait til its done...
  8. HQ08-Modder
    14 Nov 2003
    Okay im a happy as a kangaroo jumping around with his mummy and daddy in the great aussie outback because i got my white water today, and its a nice block. Havn't isntalled it tho :sigh:
    All the stuff i got:
    No idea what them green things are tho.
    Pic of green curves.
    Now the actual White Water
    Which is lapped to a near good looking mirror shine.
    And heres a height difference to a Lynx Deo Can.
    And heres the Varible Resistor ill be using on my modded Abit NF7.
  9. HQ08-Modder
    14 Nov 2003
    Okay guys, promise tommoorw.
    Get perspex cut n' stuff, gettting waterbubbler and getting gpu block.
  10. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    [threadhijack]
    dude AIM is EEEEEVVVVIIILLLL
    Anything AOL is EEEEEEEEVVVVVVVVIIIIIIIIILLLLLLLL
    [/threadhijack]
    :hehe:
    Cool project :)
  11. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    looking good m8te :)
