Storage 1tb external hard drive
Discussion in 'Hardware' started by Carlk, 23 May 2010.
  1. Carlk
    Carlk What's a Dremel?
    10 May 2004
    Hey folks,
    I need to get a reliable 1tb hard drive to use for protools, I brought a maxtor external one last year but it failed on me, I took it apart and found it was a Seagate drive! Luckly I managed to recover the data! What drives would you recomend? I'l probably be buying 2!
    Cheers,
    Carl
  2. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    Samsung F3 1TB :D
    Seagate 1TB 7200.12 as a Second Option :D
    Assuming you want a new drive to inside the enclosure... :)
  3. olimorgan
    olimorgan What's a Dremel?
    16 May 2010
    I have a 1.5 Tb Samsung Story external and very happy with it although transfering 850Gb of film by USB takes aggggggggeeeeeeeeeeeessssssssssssss!
  4. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
  5. Carlk
    10 May 2004
    Ahh yes, Icy box and f3 sounds good to me! Cheers for that folks :)
  6. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    I've had good luck the WD blacks and with F3EG
  7. seanbean
    seanbean Certa Cito
    21 Apr 2010
    When do we reckon to start seeing USB3?
  8. The_Beast
    21 Apr 2007
    Just use eSata
  9. olimorgan
    16 May 2010
    Not supported on mine. Will definately make sure it is on my next one lol
  10. Rofl_Waffle
    Rofl_Waffle What's a Dremel?
    24 Mar 2010
    I recommend the Western Digital raid edition drives. They sport a 1.2 million mean time between failure. They are a little expensive but they are worth it if you want data security.
    If you want something at the consumer level. Green drives are probably more suitable since they have a lower RPM and lower chance of failure. If you don't mind the low transfer rate that is.
