Scratch Build – In Progress 2&½
Discussion in 'Project Logs' started by Gambo, 14 Nov 2011.
  1. Gambo
    Gambo What's a Dremel?
    26 Oct 2011
    I everyone!
    This will be my first build here, as it was my first scratch/finished build ever.
    I made it earlier this year. Hope you like it. :)
    Simple concept, motherboard on top, psu and storage at bottom.
    TFX power supply, cage for 3 HDD and a sliding tray :)
    of to the building!
    main panel :D
    HDD bay - Made some changes on the original concept. The 3 were a bit too tight on the case, so I took 1 out, raised them a bit to have more clearance and put an SSD on top. :)
    SSD and some old HDDs for testing.
    motherboard tray
    structure
    Hardware in
    Front fan holder
    silicone foam for less vibration
    bottom backplate.
    the right hole will have mesh covering...
    and thats it for now. hope you all like it.
    will post the rest soon. :lol:
  2. jrs77
    jrs77 Modder
    17 Feb 2006
    Hi there. Nice start and it's another mini ITX, so I approve :p
    What will you be using this system for, seeing that you're not using a dedicated GFX-card?
  3. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Verry good start. gonna keep an eye in here.
  4. Gambo
    26 Oct 2011
    thanks guys.
    the PC is for my father, so it doesn´t need that much power.
    (although he already played COD5 in it and it managed. :) )
    the idea was really "compact" and "sober"
    I'll post lot more later tonight
  5. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    Another mini-ITX build :) Seems to be a surge in them all of a sudden and they're all awesome :) The sliding tray is perfect for such a small build knowing how fiddly they can be :)
  6. soul_train
    soul_train What's a Dremel?
    17 Dec 2009
    Amazing work m8 keep it coming :dremel:
  7. DiamondFX
    DiamondFX What's a Dremel?
    6 Nov 2011
    Nice start, I like :)
  8. adidan
    25 Mar 2009
    Looks like it's going to be a home made Lian-Li. Nice. :thumb:
  9. Gambo
    26 Oct 2011
    since the top, front and bottom are 1 piece only, it had to come out some way.. :lol:
    Hi mate! :dremel:
    ;) saying it isn't inspired by it, would be a lie. I love the small Lian-Li, though this way fits me better. :)
    more pics!
    Slim-Sata adapter
    sleeved and masked CPU fan.
    B-magic! :D
    PSU
    cut all the wires to a more suitable lenght
    more sleeving :D
    2nd ODD holder, this time with riveted pieces instead of bending 1 whole piece.
    more to come... :clap:
    Razer2007 likes this.
  10. adidan
    25 Mar 2009
    I love their small cases too, impressive metalwork skills going on there I must say.
    Keep up with the updates. :thumb:
  11. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Good metalworking dude. I like the design. Keep it up :) +rep
  12. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    More than nice job... following your project.. Suscribed!!
    :thumb:
  13. Gambo
    26 Oct 2011
    thanks guys! It was my first time working with a metal. :dremel:
    It's not any near perfect, but I'm very happy with it. :)
    next...
    painting..
    some finishing details..
    silicone foam to cover up some places
    MB tray slides perfectly, no sound or vibrations. :)
    back to the PSU
    getting rid of some wires
    cables needing a twist because of the inverted SSD.
    finished PSU! :clap:
    more case "padding"
    Padded front fan
    some assembling :)
    cheers!
  14. Gambo
    26 Oct 2011
    Thank you! :lol:
  15. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    great metalwork and paintjob!
    *watching*
  16. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    I'm mightily impressed with your metal work and brilliant paint job. Look's like it came straight out of a factory.
    You say this is your first time working with metal. That makes it all the more impressive. Keep up the great work and I will be watching with interest :).
  17. Gtek
    Gtek Doesn't raise the bar; he IS the bar.
    10 Oct 2009
    Really nice and clean job so far, keep it up :thumb:
  18. Gambo
    26 Oct 2011
    Thanks! :D
    I'm glad you like it.
    It was a very nice experience, with lots of learning for me. :)
    I too got impressed by the results.. wasn't that much confident when I started. lol
    Thanks Peter! I truly appreciate it! :cooldude:
    PSU in
    ODD adapter
    And mobo in.
    SSD in.
    bad picture just to show a 3.5" HDD next to the the case..
    HDD in.
    and some more pics :D
    final cable sleeving..
  19. nathandanielmorris
    nathandanielmorris What's a Dremel?
    23 Jan 2011
    Wow. I'm looking to build a compact low-profile HTPC, and if you don't mind me saying this has given me some inspiration and a few ideas that I think I might well pinch!
  20. yassarikhan786
    10 Aug 2011
    Brilliant job on the sleeving and cable management.
    Haha, I like the comparison with the HDD. I didn't think the case would be that small :).
