Networks 2 + Http Servers on Port 80
Discussion in 'Hardware' started by Mortus, 6 Dec 2005.
  1. Mortus
    Mortus What's a Dremel?
    30 Sep 2004
    Afternoon all, i require some know how with http servers and tunneling etc?
    Basically i have a HTTP server running on an old PC at home with pictures etc on ..... people outsite my home network on the internet can see this and view the pics.
    However i now want to run another server on port 80 (i need to use port 80 because of people behind firewalls etc whom can only see port 80)
    So i wondered if there is something i can use on my server or maybe do something like this?
    Any input would be great thanks.
    -Mortus
  2. mcbeckel
    mcbeckel What's a Dremel?
    31 Aug 2003
    Subdomains...link
  3. Mortus
    30 Sep 2004
    That seems to give me multipul sub domains but on one http server i need to use differment servers.
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    So you want two webservers both running on the same port on one machine with one IP address?
    Cant be done to my knowledge.
    If they were running on different ports and/or IPs id be fine.
  5. Mortus
    30 Sep 2004
    No two/three webservers running on different machines on the same external IP ..... different internal IP's but the same port.
  6. Atomic
    Atomic Gerwaff
    6 May 2002
    What router are you using?
  7. Mortus
    30 Sep 2004
    Well i will be using a Linksys HR200
    Even If i have to use a dedicated machine for the routing i dont mind ........ i can double it up as a file server or something.
    thanks
    -Mortus
  8. simon w
    simon w What's a Dremel?
    3 Nov 2003
    You can't bind more than one service (i.e. an instance of a web server) to the same port. Apache virtual hosts will allow you to host multiple websites on web server using the same port.
    I believe the correct question that you should be asking is "How can I host multiple web sites on one web server?"
  9. Mortus
    30 Sep 2004
    No i dont want to host multiple website on one web server
    Ill Try to explain a little better
    External IP on the router......
    Machine 1A IP=192.168.0.5 Running Apache / Photo Album
    Machine 1B IP=192.168.0.6 Running Media Portal With WebAccess (HTTP Server)
    Machine 1C IP=192.168.0.7 Running Apache / Website with Forum
    So i would like to be able to access all three but through Port 80 on the external IP .......... Different ports can be used internally but i need to gain access through 80 externally.
    Hope that is a little clearer.
    thanks
    -Tom
  10. coorz
    coorz Miffed
    25 Apr 2003
    Hyperlink to the other servers on the startpage?
    What's wrong with putting the other servers on different ports, just add the port when you type in the URL.
  11. kiljoi
    kiljoi I *am* a computer king.
    13 Oct 2003
    There's no way to have multiple servers using the same external firewall port.
  12. Atomic
    Atomic Gerwaff
    6 May 2002
    You cant port forward (using a router like you have) to more than one machine.
    All the websites will have to be one one single machine, you have no choice in that matter.
    Personally Id just use subdomains, its easiest :p
  13. Mortus
    30 Sep 2004
    I was thinking something along those lines my self.
    Cant use different ports becuase myself and other people who will access the servers can only use port 80 becuase we're behind a firewall.
  14. Mortus
    30 Sep 2004
    I know i can't portforward ........
    I read the thing about using apache and subdomains but from what i read it wouldnt work for me? Becuase im using numbers IPs without a domain name as such?
  15. Atomic
    Atomic Gerwaff
    6 May 2002
    You cant do what you want to. 4 people have told you this now :p
    External Port 80 can ONLY be forwarded to ONE internal machine not three like you want. And port forwarding is the only way of doing what you want
    Your limitation is only being able to use a single port (80 in your case)
  16. Mortus
    30 Sep 2004
    Ok so port 80 can only go to one machine.
    Is there any way to tunnel things through a one machine.
    Im also using an ADSL modem that has NAT and PAT so i guess i should see if i can buy another IP from my ISP.
    -Tom
    Thanks for the input ALL :)
  17. thingamajig
    thingamajig What's a Dremel?
    29 Nov 2005
    A Quick Google Search Lead Me To This link
  18. unclean
    unclean SMP obsessive
    30 Dec 2003
    You could have one webserver "proxy" the other webservers and have virtual hosts so they would be available via subdomains.
    So.. you have three subdomains all looking at the same IP. port 80 forwarded to one server, that server would then see the subdomain request and, using something like apache virtual hosts, serve a different site on the same IP. (basically the webserver looks at a different documentroot based on the subdomain requested).
    Once you've set that up you can have a script in each of said subdomain's document root, or using some features in IIS (if you're using 'doze) to forward pages from the other webservers.
    An easier way on any server would be to mount a network share on another PC and then use that as the documentroot on the webserver, but that won't work with stuff that needs to be generated on the remote machine and proxied.
    I'm really not sure why you'd need three webservers on a home connection though, you can just use the virtualhosts method to serve apparently seperate websites on the same IP.
  19. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    You can't port forward one port to multiple computers. I suggest contacting your ISP to buy more external IPs.
  20. Mortus
    30 Sep 2004
    My ISP can't/wont give me any more IP's
