Planning 2 systemsoff 1 psu?? possible??
Discussion in 'Modding' started by SenseiOnIce, 11 Jan 2011.
  1. SenseiOnIce
    SenseiOnIce What's a Dremel?
    11 Jan 2011
    Hey guys, for an upcoming mod i have in the planning phase, i wanted to know, is it possible for me to run 2 systems off 1 psu??
    they are both mini-itx boards, one with a 760 and the other with a going to be overclocked i7 2600k sandy bridge. if i split the atx 24-pins, and routed them to a different system, would it still work or would the combined amperege pulldown kill the psu? i already have a plan for doingthe power good signals so dont worry about that! any help would be nice. i am planning on using a 1200 watt cooler master silent pro gold single rail. thanks in advance.
    i actually was reading the reviews for this psu, and its not the best. so i was wondering, are there any other good ones out there that are single rail?? im leaning towards the corsair ax1200or the enermax revolution 1020w. oh and i probably will have a 5870 on the sandy bridge one.
  2. bulldogjeff
    2 Mar 2010
    it's possible but you'll need a splitter for the 24 pin. Which will probably mean making one. whether it'll will still work is any ones guess. I would go for 2 smaller PSU's 500w and put a jumper lead in to fire both rigs off one switch.
  3. djzic
    djzic Bokehlicious!
    8 Nov 2010
    Or use a relay switch.
  4. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    You mean like this?
    http://tv.hexus.net/show/2011/01/CES_2011_Two_computers_from_one_PSU_That_ll_be_Antec_antics_then
  5. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
    Why wouldn't it? As long as the PSU is powerful enough you could have a 10000 comps running off it but they will only every be on at the same time.
    It may be nothing but I would be a bit concerned with the power/on switch wire to the PSU with two mother boards. I would probably just send it to one of the boards and just use that one to turn both of them on.
