Case Mod - Complete ⭐ 2018 - Project: Machine
Discussion in 'Project Logs' started by Reza Ghafarian, 20 Nov 2018.
  1. Reza Ghafarian
    Reza Ghafarian What's a Dremel?
    13 Nov 2018
    2018 - Machine by (Reza Ghafarian a.k.a Machine)
    Instagram: ghafarian.r
    Email: ghafarian.r@gmail.com
    Owner: Farzad Arabshashi
    Cost: $11,250
    Project Duration: Completed in the course of one year & half
    Weight: 47 Kg
    CPU @ 5.1 GHz
    GPU @ 2164 MHz
    3dMark Score | Time Spy Test: 15,687
    Parts:
    Water Cooling
    # Vendor Item
    1 Thermaltake 1000mm V-Tubler PETG Hard Tubing, 4-Pack
    2 Corsair Air Series AF140 Quiet Edition Single Fan
    3 Corsair Air Series SP120 PWM Quiet Edition - Twin Pack
    4 EKWB EK-AF Angled 2×45° G1/4 Black
    5 EKWB EK-AF Angled 90° 2F G1/4 Black
    6 EKWB EK-AF Angled 90° G1/4 Black
    7 EKWB EK-AF Ball Valve (10mm) G1/4 - Black
    8 EKWB EK-AF Extender 12mm F-F G1/4 - Black
    9 EKWB EK-AF Extender 12mm M-M G1/4 - Black
    10 EKWB EK-AF Extender 20mm M-F G1/4 - Black
    11 EKWB EK-AF Extender 20mm M-M G1/4 - Black
    12 EKWB EK-AF Extender 30mm M-F G1/4 - Black
    13 EKWB EK-AF Extender 6mm M-M G1/4 - Black
    14 EKWB EK-AF Extender 8mm M-F G1/4 - Black
    15 EKWB EK-AF Extender Rotary M-F G1/4 - Black
    16 EKWB EK-AF Extender Rotary M-M G1/4 - Black
    17 EKWB EK-AF Pass-Through G1/4 - Black
    18 EKWB EK-AF T-Splitter 3F G1/4 - Black
    19 EKWB EK-Cable PWM Fan Extension (30cm)
    20 EKWB EK-Cable Splitter 4-Fan PWM Extended
    21 EKWB EK-CoolStream SE 480
    22 EKWB EK-CoolStream XE 360
    23 EKWB EK-CoolStream XE 480
    24 EKWB EK-CSQ Plug G1/4 (for EK-Badge) - Black
    25 EKWB EK-FC1080 GTX Strix - Acetal+Nickel
    26 EKWB EK-FC1080 GTX Strix Backplate - Black
    27 EKWB EK-HD Adapter 12/16mm - Black
    28 EKWB EK-HDC Fitting 16mm - Black (6-pack)
    29 EKWB EK-M.2 NVMe Heatsink - Black
    30 EKWB EK-RES X3 - Internal Tube 12/16 140mm
    31 EKWB EK-RES X3 - Multiport TOP
    32 EKWB EK-RES X3 250
    33 EKWB EK-Supremacy EVO - Acetal+Nickel
    34 EKWB EK-UNI Pump Bracket (120mm FAN) Vertical
    35 EKWB EK-XTOP Revo D5 PWM - (incl. sleeved pump)
    36 Bitspower G1/4" Temperature Sensor Stop Fitting, Matte Black
    37 EKWB Mayhems X1 Black Concentrate - 250ml
    38 Singularity Computers Reservoir Mount: Ethereal Dual V3
    Modding
    # Vendor Item
    1 Mainframecustom 10pin Dupont Connector
    2 Mainframecustom 10pin Female Connector
    3 Mnpctech 14 Pin Carbon Fiber Black Cable Comb
    4 Mainframecustom 18pin Female Connector
    5 SilverStone Technology 2.4G Wireless Computer Remote
    6 Mainframecustom 20+4pin ATX Female Connector
    7 MDPC-X 23-AWG hook-up wire C-WHITE
    8 Mnpctech 24 Pin ATX Carbon Fiber Black Cable Comb
    9 Mnpctech 4 Pin Carbon Fiber Black Cable Comb
    10 Mainframecustom 4pin EPS Female Connector
    11 Mainframecustom 4pin Fan Female Connector
    12 Mainframecustom 4pin Fan Male Connector
    13 Mainframecustom 4pin Power Female Connector
    14 Mainframecustom 4pin Power Male Connector
    15 Mnpctech 6 Pin Carbon Fiber Black Cable Comb
    16 Mainframecustom 6+2pin PCI-E Female Connector
    17 Mainframecustom 6+2pin PCI-E Female Connector
    18 Mnpctech 8 Pin Carbon Fiber Black Cable Comb
    19 Mainframecustom 8pin EPS Female Connector
    20 ColdZero 900D 5.25" Front Bay Cover
    21 ColdZero 900D Front Panel (Blank) - Customed
    22 ColdZero 900D Full Size MB Tray Cover
    23 ColdZero 900D Midplate - Long (Rev. 3) - Customed
    24 MDPC-X Anthracite Heat-Shrink 3.4:1 MEDIUM 1m
    25 MDPC-X Anthracite PRE-CUT Heat-Shrink 4:1 SMALL 50x
    26 MDPC-X Black Cable Management Clip BIG 10x
    27 MDPC-X Black Cable Management Clip JUMBO 10x
    28 MDPC-X Black Cable Management Clip MEDIUM 10x
    29 MDPC-X Black Cable Management Clip SMALL 10x
    30 MDPC-X Black Cable Sleeving MEDIUM 33m
    31 MDPC-X Black Cable Sleeving SMALL 100m
    32 MDPC-X Cable-Combs BLACK O-24
    33 MDPC-X Cable-Combs BLACK O-4
    34 MDPC-X Cable-Combs BLACK O-4-SR
    35 MDPC-X Cable-Combs BLACK O-6
    36 MDPC-X Cable-Combs BLACK O-8
    37 Mainframecustom Female ATX Terminal (18AWG/16AWG) – (100 Count
    38 Mainframecustom Female Fan Terminal – Molex (Single)
    39 ColdZero HDD Cover (Blank) Black
    40 Mainframecustom M1 Custom 2mm OD White 16 AWG - (25ft)
    41 Mainframecustom M1 Custom White 18AWG (25ft)
    42 Junter M3(3mm) Black Alloy Steel High Tensile Allen Bolts Hex Button (Set B Button Head) 300pcs
    43 Junter M3(3mm) Black Alloy Steel High Tensile Allen Bolts Hex Button (Set C Flat Head) 300pcs
    44 Mainframecustom Male 4pin Power Terminal – (5 Count)
    45 Mainframecustom Male Fan Terminal – (5 Count)
    46 Corsair Obsidian 900D
    47 Phanteks RGB LED Strip 40cm
    48 Mainframecustom Sata Power Crimp Style Connector
    49 Mainframecustom Sata Power Crimp Terminal – (5 count)
    50 EKWB Screw set UNC 6-32 30mm (20 pcs)
    51 EKWB Screw set UNC 6-32 5mm (20 pcs)
    52 ColdZero SSD Cover (Vertical) Black
    Hardware
    # Vendor Item
    1 Western Digital Black 4TB
    2 Intel Core™ i9-7900X X-series
    3 Samsung EVO 960 M.2 512gb
    4 Samsung Pro 850 1TB
    5 EVGA PRO SLI HB Bridge (2-Way) -80 mm
    6 Asus ROG RAMPAGE VI EXTREME
    7 Asus ROG Strix 1080 OC
    8 EVGA Supvernova 1600W Gold
    9 G.SKILL TridentZ Series DDR4 (8 x 8GB)
    10 ADATA XPG SX900 512gb
  2. Reza Ghafarian
    13 Nov 2018
  3. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    This looks great. Would love to see you do a full project log for your next build.
    Reza Ghafarian likes this.
  4. Reza Ghafarian
    13 Nov 2018
  5. Reza Ghafarian
    13 Nov 2018
    Hello there. The project took 1 year and half I do have lots of photos of this project. Eventually I'm going to post the log here.
  6. Reza Ghafarian
    13 Nov 2018
  7. kim
    kim hardware addict
    10 Jan 2016
    :rock:yeah man, now we can see, and it worth it :thumb:, splendid work, awesome result, I'd love to see the whole set of pics, don't hesitate to post it mate, we want to see :grin:
  8. Vault-Tec
    30 Aug 2015
    Wow, you could have bought a nice car with that money..... I'd rather have the PC :D
    Lovely build.
  9. Cheapskate
    13 May 2007
    Much better. :D That's a nice clean build.
  10. Reza Ghafarian
    13 Nov 2018
    Thank you so much. I will post all of them. :clap:
  11. Reza Ghafarian
    13 Nov 2018
    I know! right? :blah: :clap::naughty:
  12. Reza Ghafarian
    13 Nov 2018
    Thank you so much. :naughty::lol::hehe:
  13. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Zip ties have no place on a 11,000 dollar pc :nono:
    If it wasn't for the zip ties the build is so clean i might have thought it was a render:rock:
  14. Reza Ghafarian
    13 Nov 2018
    Dear DÈF¥âÑt¸.·´¯`¤,
    Thank you so much for your kind words. I do respect your opinion. For me the looks of the zip ties just work... results in industrial aesthetics. Specifically I like this one the most:
    I did allocate some time for photography and post processing the photos. So the result is super clean. It looks like render for me too. :lol:
    Btw, I checked your work! Amazing job!
  15. Reza Ghafarian
    13 Nov 2018
    Machine before departure to Shiraz.
  16. ratzofftoya
    ratzofftoya What's a Dremel?
    25 Jun 2013
    What are the thin pieces of metal on the backside of the mobo tray?
