Education 3D Printing
Discussion in 'General' started by Astroreeper, 24 Dec 2010.
  1. Astroreeper
    Astroreeper What's a Dremel?
    18 May 2010
    Hey chaps. Anyone out there tried building a 3d printer on the cheep?
    Iv'e seen lots of very expensive machines, doing something that in theory is quite simple. There must be a better way to make your own modding parts.....
  2. jhanlon303
    7 Sep 2006
    Hire Cheapskate?
  3. deadsea
    deadsea What's a Dremel?
    9 Oct 2009
  4. Sheiken
    Sheiken Wat?
    9 Jan 2005
    There is also the makerbot
  5. profqwerty
    profqwerty What's a Dremel?
    2 Jan 2006
    check out hackaday.com! There's loads of 3d printer hacks :)
  6. theevilelephant
    theevilelephant Minimodder
    5 Jan 2006
    Both the reprap and the makebot are fairly cheap and do a decent job. The quality of the printed material isn't amazing but it's still pretty good considering how little the hardware costs.
  7. feedayeen
    feedayeen What's a Dremel?
    18 Jun 2008
    Milling machines are generally superior for projects. 3D printers have an advantage in that it is more difficult to create certain shapes with hidden surfaces with millers but this is a small benefit to the numerous downsides.
    materials: 3d printers are essentially limited to plastics with certain thermal properties, usually not very strong too, millers can work from everything from plastic to steel
    speed: millers are usually faster because there is no cooling time for the substance to set.
    accuracy: millers have an order of magnitude percission among consumer level hardware, .1mm accuracy to something near or better than .01mm, this means no blockyness which is rapidly becoming a trademark of 3d printing.
  8. kingred
    kingred Surfacing sucks!
    27 Mar 2008
    3d printers are a fantastic invention, with newer materials and methodologies being innovated upon everyday.
    Its purely dependant on how much you want to spend, the accuracy issues you have also depend on how your going to finish your model really,its generally used like wood as its an isometric material (grain of the material flowing one way) so you have to really design your model so it works with the grain (flat for compression, edge on for tension) so it doesn't split.
    There are metal additive material processes coming in but are in general very expensive as they require very specialist care and love to keep going.
    The cheaper polymer ones like makerbot are fantastic as you can load them with any thermoplastic and do some really cool things with composite material.
    The world is your oyster really :) :dremel:
