Graphics 3Dmark05 released - Lets see your results.
Discussion in 'Hardware' started by jetsetjimbo, 29 Sep 2004.
  1. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    Well beat my score my amazing *not* 5200 128mb 64bit memory has achived this massive score: 258 it ran around a frame every 2 seconds! :clap:
  2. Yadda
    Yadda Minimodder
    25 Jul 2003
  3. bimy
    bimy What's a Dremel?
    5 Oct 2004
    I updated my drivers for my GF6800 GT, and I got like 500 pts more now :D
    linky
  4. Tolsk
    Tolsk What's a Dremel?
    14 Jul 2004
    thought id bump this because people are posting o5 piccys in the o3 thread
  5. Tolsk
    14 Jul 2004
  6. Solutions
    Solutions What's a Dremel?
    24 Jan 2005
    I am having a hell of a time breaking the 9K barrier. My highest 3DMark05Pro score has been: 8975 but I am hoping to surpass that when I replace my RAM. I was hoping to be able to break 9K using air cooling (and probably could) but my RAM craps out before the air-cooled CPU or video cards do...
    I guess I could turn down the image quality settings just to be an official member of the 9K Club but I would hate to have to "cheat" like that. So far all my 3DMark05 settings are stock/default.
    Not sure if this link will work but here is my best score: http://service.futuremark.com/compare?3dm05=511652
    ****ABOVE LINK CORRECTED****
    Anyone know why the Video clock/mem speeds are all hosed in the score results?
  7. Tolsk
    14 Jul 2004
    richy 2 6800's. and your not even tripleing my 6800 vanilla
    Edit: Solutions, you need to igve us the compair link
  8. Solutions
    24 Jan 2005
    Is there a link on the Futuremark website for viewing the highest score recorded? I'd like to see what the highest obtainable score is so that I can make it my goal.
    You are right....I am not tripling your vanilla... YET! That score was achieved with no video overclocking and I believe SLI was disabled. Hopefully some new RAM will open things up for me as that seems to be my current bottleneck.
    One thing I have noticed with the SLI setup, so far, is that I have been unable to OC the core speed above 445. I don't think it has to do with heat though because The "Test Changes" setting won't approve anything over 445 for me and I doubt during its testing period that it actually gets hot enough to cause stability issues. I dunno... should know if heat is the issue by this weekend (Danger Den GPU blocks in the mail.)
  9. Harlequin
    Harlequin Modder
    4 Jun 2004
  10. Solutions
    24 Jan 2005
    WOW... looks like I have some serious tweaking to do.... Those dudes are almost up to 13K!
  11. renimatorius
    renimatorius What's a Dremel?
    14 Jul 2004
    HIS Excalibur 9550 def 250/200, turbo 430/261, hynix 5 :waah:
    3Dmark2001se-11538
    3Dmark03-3138
    3Dmark05-1304
    AquaMark3-27134
  12. j.rhy@n
    j.rhy@n What's a Dremel?
    10 Feb 2005
  13. Blackfish23
    Blackfish23 Minimodder
    13 Oct 2004
    6540 With sig, but 512 corsair LLPT rather than gig of patriot. A64 at stock.
  14. TMM
    TMM Modder
    12 Jan 2004
    http://service.futuremark.com/compare?3dm05=675155
    2984
    Athlon64 3200+ skt939 @ 2500mhz (10*250)
    Abit AV8
    2x 512mb kingmax 3700 @ 2.5-2-2-5-7-9 (cpu/12)
    9800pro (R350) @ 435core 401mem
    pretty close to 3k now... the mem on my 9800pro loves 3dmark05 :D could probably push 410mhz if i put some ramsinks on the buggers.
  15. TMM
    TMM Modder
    12 Jan 2004
    Athlon64 3200+ @ 2670mhz (10x267)
    MSI K8N Neo2 Plat
    PowerColor 9800PRO @ 440/400, 71mhz AGP
    2x 512mb Kingmax PC3700 @ "333" 2.5-3-3-10
  16. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
  17. TMM
    TMM Modder
    12 Jan 2004
    Hmm odd. My cpu score is much higer then yours at a lower clockspeed?
    On CPU test1, 2.5 fps vs. 3.6fps. 2760mhz v.s 2670mhz. CPU test2 is identical fps though.
  18. Cheap Mod Wannabe
    Cheap Mod Wannabe What's a Dremel?
    7 Feb 2005
    I have fx5900xt by MSI and I get only a little bit above a thousand (depends on OC) And you know what, I don't give a $%|T cause HL 2, Doom 3 are playable and enjoyable on average video settings. But most importantly I get max online fps in UT 2k4 thus I save money and wait for new technological advances in graphic card industry... =D
    Although If I'd have money to spend I'd definetly upgrade.
    3Dmark 2005 was a bit too rough. Previous version were more of a global benchmarking however the latest version became only high-end system benchmark. Maybe because they are not planning to release new version soon...
  19. TMM
    TMM Modder
    12 Jan 2004
  20. TMM
    TMM Modder
    12 Jan 2004
