Modding 40 to 44 pin IDE connectors
Discussion in 'Modding' started by DigitalReligion, 5 May 2004.
  1. DigitalReligion
    DigitalReligion What's a Dremel?
    5 May 2004
    I've been looking for a pin out diagram for laptop hard drives, mainly which pins are for powering the drive. I'm probably going to craft my own adapter for a 2.5in laptop drive i have rather than buying one.
  2. Vochraye
    Vochraye What's a Dremel?
    21 Mar 2004
    I don't know where to find the pin out, but these images (2) (3) (link to full article) might help you - they clearly show the traces to the pins and indicate which is pin 1. You should be able to reverse engineer the rest.
  3. DigitalReligion
    5 May 2004
    Thanks, thats a good set of pics ;)
  4. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
  5. Vochraye
    21 Mar 2004
    Where's the fun in that? [​IMG]
  6. BjD
    BjD What's a Dremel?
    10 Apr 2003
    Damn right :D I chopped a 40 and 44 way cable in half and connected then together, all 40 lines soldered and heatshrinked. Except that was the other way, 44 header on meh amiga 1200 to a brick of a 200mb drive.
    The 2.5 connector is the same 'layout' as the larger type, except the last 4 pins are for power. Nice picamatures here . :thumb:
