Memory 4133 on Ryzen
Discussion in 'Hardware' started by Vault-Tec, 21 Mar 2020.
  1. Vault-Tec
    30 Aug 2015
  2. adidan
    25 Mar 2009
    Had it running at any other speeds like 3200 or 3600?
    Edit: although xmp should really work out of the box
  3. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    Ryzen 3XXX chips should be fine. Ryzen 2XXX chips all top out at 36-something, but I'm assuming this in your new Ryzen 9 system?
    #Edit. Randomly the Asus specs for the X570 TUF list 4400 and 3466 but nothing in between. Maybe it's the board doesn't like those settings.
    Vault-Tec likes this.
  4. Vault-Tec
    30 Aug 2015
    Looking back at the link didn't fill me with hope.
    It is running 3200 fine as I type this, I'll push a little harder in a bit.
  5. adidan
    25 Mar 2009
    The FCLK 1:1 ratio tops out at 3733 doesn't it? Would the FCLK need to be manually set for anything above that to stop it kicking in a 2:1 memory to infinity fabric ratio?
    I think the benefit of faster ram is dropping it to 3600/3733 and getting tighter timings? Sorry, kinda working of my own memory and don't know if much changed with the 3000 series.
  6. faugusztin
    11 Aug 2008
    1:1 ratio tops at 3800MHz, in case your CPU is even capable of running the infinity fabric at 1900MHz (not all chips are capable). That is why DDR4-3600 is recommended, as that puts IF to 1800MHz, which nearly all CPUs could do.
  7. Vault-Tec
    30 Aug 2015
    I don't even know what an FCLK is yet. I'll play some more tomorrow, I've proper done my back in sitting on the floor for 8 hours. If I can even move tomorrow, that is.
  8. Vault-Tec
    30 Aug 2015
    Ta. Will look again tomorrow.
  9. faugusztin
    11 Aug 2008
    This was in the 3rd gen ryzen slides:
    adidan and Vault-Tec like this.
  10. adidan
    25 Mar 2009
    That's the bugger I was looking for, but I went to bed though :happy:
    Edit: @Vault-Tec you may have checked the manual anyway but iirc but on my board I had to use specific dimm slots for ram above a certain speed in a paired set.
  11. Vault-Tec
    30 Aug 2015
    Yeah they were in the wrong slots at first. They were then in single channel, so I figured it out. Not easy when your board is upside down lmao.
    I'll have a play later. Been doing some reading this morning :)
    adidan likes this.
