Graphics 4870 X2 length
Discussion in 'Hardware' started by Igniseus, 6 Jul 2008.
  1. Igniseus
    Igniseus What's a Dremel?
    5 Mar 2006
    Hey all,
    Does anybody know or can guess if the 4870 X2 is going to be as long or longer than the 8800GTX? I imagine its bigger than the 4870 but hoping not quite as long as the 8800GTX.
    Thanks
  2. atanum141
    22 Jul 2004
    Im not sure of the exact size but you can bet it will be longer easily.
  3. Igniseus
    5 Mar 2006
    Longer than the 8800GTX!? :O
  4. heir flick
    heir flick Minimodder
    2 Feb 2007
    intrested to find this out myself, as long as it not bigger than the 3870x2 i should be ok
  5. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
  6. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    or 7 1/4 inch (18 1/2 cm) long for those without the ability to put a tape measure next to their screen without caring if it scratches:)
  7. wyx087
    15 Aug 2007
    i think it's the same length as all the big cards (8800GTX, Ultra, 9800GTX and 3870x2)
  8. Jhonbus
    Jhonbus What's a Dremel?
    1 May 2005
    Judging from the length of the PCI-E connector, the one in that pic is roughly 30cm long!
  9. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Measured the scale factor then measured the one onscreen.
    It's about 30cm.
  10. Igniseus
    5 Mar 2006
    Damnit, wont fit in my case then :( 8800GTX just fit in with 1CM to spare max....
