Graphics 5770, 5750 or wait for fermi
Discussion in 'Hardware' started by mbvg, 29 Oct 2009.
  1. mbvg
    mbvg e5300 all the way
    7 Oct 2009
    hi,
    at mo have an radeon x600 series GPU but want to upgrade. i don't want to spend much at all ( the less the better) but would like to in future play empire total war.
    am looking at the value end (would be happy to pay this much)
    nvidia geforce gts 250 = £80
    This is the mid and not so happy to pay end of my list
    hd 4870 = £98
    hd 4770 = £100
    hd 5750 = £109
    hd 5770 = £125
    PSU = 460W and have only 1 six pin connector on PSU but many free molex conectors
    CPU = cual core e5300 @stock 2.6Ghz
    are there any other models i should look at at either end? (remember less the better)
    but need help on which to buy and which are better but need it on a budget
    £80-£85 max for value
    £100-£125 for mid range
  2. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    dont wait for fermi, they wont be cheap. if nvidia do release any 'cheap' cards they will just be re-branded old models (a la gts 250).
  3. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    they make gts230 cards that are 9600gso cards (hmm think they are doing that for OEMs right now but support DX10.1 as well pointless but they do)
  4. trig
    trig god's little mistake
    10 Aug 2006
    w/e you do, make sure you have the amps on that psu to run w/e you get. not sure what games you play or at what rez, but based on the card you currently run it can't be too demanding. i'd go with the gts...no need to spend the money if you don't use the grunt...plus when fermi comes out and has budget options, you could still get a little out of yours without taking too much of a hit...if it ends up being worth it.
  5. bitbirchir
    bitbirchir What's a Dremel?
    30 Oct 2009
    a la gts 250
  6. mbvg
    7 Oct 2009
    in future want to play empire total war or stradagy games of some kind
  7. Elton
    23 Jan 2009
    I'm tempted to suggest to wait for fermi, even if they are expensive ATI card prices are sure to lower hopefully a bit.
