60C hehe
Discussion in 'Hardware' started by J453, 12 Apr 2004.
  1. J453
    J453 What's a Dremel?
    31 Jan 2004
    Yay, my CPU now goes to 60C when i play games. Isn't that just ****ing great?!?!
    I mean, its only overclocked ever so slightly (2800 @ 3200).
    Its on a Volcano 9 (piece of ****) but the stupid mongod thing is, i have an SK-7 and my mobo(s) dont like it (noobs) so im stuck with this temp then.
    Cant be all too bad bartons are rated at 85C critical.
  2. Carbon
    Carbon Banned
    8 Jan 2003
  3. J453
    31 Jan 2004
    sarcastic remark at the fact i have a highish performance cooler that dont work so i have to stick with stupidly high temps...
    EDIT: it dont work as in the pc doesnt post with it..
  4. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    thermal paste??
    get a decent cooler?? i know that their hard to find, but alpha pal 8045 still seems to be a fairly good option!!
  5. J453
    31 Jan 2004
    i spent 20 quid on that damn copper lump and it refuses to let my pc boot. it is seated correctly, the fan works, ive tried 4 fans, thermal paste that came with it is properly applied. (i dont want no AS3/5) so wtf is up with it, is 60C really all that bad?
  6. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    yes 60C is horrible, but it could be a bad sensor, feel the HS while the comp is on, is it really that hot?
    I have a PAL 8045 and am running at 40C on a XP1900(palomino) OC'ed to 1704Mhz, (142x12) 1.718V plus my room is pretty warm right now. (24C ambient case temp)
    Did you change the voltage any, what temps do you get stock?
  7. J453
    31 Jan 2004
    ive not changed any voltages, just bumped up fsb and lowered multi, it burns if i touch it for too long so yeah ir prob is that hot.
    Not sure what temps i get stock.. if i had to guess id say 10C lower maybe :confused:
  8. rio2
    rio2 What's a Dremel?
    8 Apr 2004
    increase fun at your case 60°c is very high temperature for this system.
    normaly my barton xp2500@xp3200 is a35-37 °c high temperature is dangerouse for long life of cpu. :waah: :wallbash: :duh:
  9. wharrad
    wharrad Minimodder
    26 Jul 2003
    Ah, my p4-C runs at 60C under load (using the stock heatsink until I get some water in there, long story).
    Every so oftern it creeps up to 65C, then I open the case - stick in the hoover to remove some dust - the temps fall into the low 50's for awhile (and low 30's idle).
    So maybe try cleaing the thing as much as possible, but I figure you might have cleaned it with changing the heatsink and everything.
  10. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    cold room then, huh?
  11. Tim S
    Tim S OG
    8 Nov 2001
    heat isn't a problem if you're stable... also running 24/7 at a high temperature will not affect your CPU life span as much as people make out... the problem is where you're constantly changing the temperature by huge amounts - this is where good cooling comes in...
    AMD's Cool & Quiet technology doesn't necessarily utilise this; but what it does do makes perfect sense... cooler components last longer; and when you stress (overclock) components, the cooler you keep them, the longer they will last.
    AMD spec their processors up to 90'C so you can run up to that temperature with them, safely... I would start to worry if you get above 75'C though. Intel spec their processors slightly lower, at around 75'C... they begin to throttle around this speed - this makes the job harder for OEM system builders, they can't skimp quite so much on cooling in an intel system.
    Take motherboard readings with a pinch of salt.... if it runs prime 95 stabilly for 24 hours... heat isn't a problem; the same goes for games.
  12. J453
    31 Jan 2004
    Cheers BigZ. I aint scared of it now lol.
    It runs everything stable and im keeping it at a 3200+ so its not changing rapidly.
  13. Tim S
    Tim S OG
    8 Nov 2001
    no problem :thumb:
  14. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    I have the same processor, but it is not overclocked to 3200 as it doesnt work (how did u do it? Better cooling?) and I'm reaching 62.5C when the processor is running at 100%, and when its idle - no less than 59C. I have a standard AMD cooler with a bit of lighting on it. What do u suggest to lower the temp? Better cooling? And if so which?
    I'm not bothered at all about noise (I'm deaf!!!), just want a cooler CPU
  15. felix the cat
    11 Jan 2002
    get a decent heatsink....sp97 (somethin like that) pal 8045 (hard to get) or a swiftech...add any fan you like!
  16. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    What speed is the fan running? The sink *should* be rated to 3400+ so temps shouldnt go as high as 60! Check the postition of the temp sensor or remove it totally and see if that helps.
    What mobo are you running? It might be that the alphas (great coolers btw, keep both cpu's under 45 load on silent air), or other coolers wont fit as your board doesnt have mounting holes.
    As mentioned though if its stable then theres no probs. The shuttle PC's regularly run hot (m8's runs at 62 load and no problems at all)
    willywonka, as flix said, better cooling :D
