Cooling 9/16 thread tapping
Discussion in 'Hardware' started by silentphoenix, 13 Feb 2006.
  1. silentphoenix
    silentphoenix What's a Dremel?
    1 Sep 2004
    Ive got a number of dd hi-fow barbs that are being wasted and am wondering where i could purchase some tapping bits (is that what they are called?) to make my res and dcc plexi top suitable for 9/16 thread barbs (i.e. the dd high flow ones).
    Ay you can tell, i dont know much about what im doing so any pointers would be appreciated (do i tap with a hand drill?)
  2. Risky
    Risky Modder
    10 Sep 2001
  3. silentphoenix
    1 Sep 2004
    thanks for the reply mate.
    they have a 9/16 tap, in many diffferent flavours - help!
  4. Risky
    Risky Modder
    10 Sep 2001
    Coolermeister will almost certainly know on this one
  5. clocker
    clocker Shovel Ready
    21 Dec 2003
    Definitely DO NOT try tapping with a drill.
    You may have to drill out your existing barb holes (1/2" is the correct starting size for a 9/16-18 thread).
    Then tap the holes by hand.
    Dishwashing detergent makes a good lubricant when you're tapping plastics but you have to clean the tap after so it doesn't rust.
  6. Firehed
    15 Feb 2004
    Well you need a 9/16-18 tap (18tpi, 9/16" dia); it's a standard fine-thread bolt size (at least in the states). I think the one you want is in the UNF section of the page linked to above.
    Which reminds me... I still need to get some BSP taps. You just can't find the darned things in the states.
  7. thingamajig
    thingamajig What's a Dremel?
    29 Nov 2005
    ebay
  8. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    Mcmaster has a few if you search for "NF Taps".
