Modding 90 degree molex!
Discussion in 'Modding' started by Altron, 8 Apr 2003.
  1. Oclocker
    Oclocker What's a Dremel?
    21 Jun 2001
    Yes I have been talking to Molex in the UK - but to be honest - plonkers - they didn't know they sold them until I quoted part number & they never did come back to me with a price (probably because I told them not to bother if unit price was >40p in 1000 quantities..) - normal molex females cost me under 10p each. But I have to crimp & solder all adds time :(
  2. Seal
    Seal What's a Dremel?
    2 Feb 2003
    ooooooooooooooh! right, oops sorry.
  3. iggy
    iggy Minimodder
    24 Jun 2002
    for the evil baybus empire no doubt :D
    no luck so far btw :/ and im beginning to feel a desperate need for sleep. rewired the whole house with cat6 in readiness for broadband D-day, but im short of faceplates, so i might try down at the local place when im down there, pretty knowledgable folk down there
  4. Snood
    Snood What's a Dremel?
    27 Feb 2003
    whats the difference between cat 5 and cat 6?
    Snood
  5. Altron
    Altron Minimodder
    12 Dec 2002
    Check out Leviton, they have faceplates. My uncle used their stuff for his home networking project (well of course he did, he writes all their software)
    I know Cat5 is 8 strands of 24ga solid core copper wire, not sure about Cat6 though. Maybe it's bigger or thicker or faster.
  6. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    cat 6 is bigger wiring capable of supporting gigabit lan.
  7. Dad
    Dad You talkin to me?
    15 Apr 2003
    Right.
    Cat-3: designed for <= 10M/b nets and voice
    Cat-5: designed for <= 100M/b nets
    Cat-5e: pretty much same as cat-5, but works a LOT better on 100M/b nets
    Cat-6: designed for gigabit nets
    All wire is backwards compatable so you can use cat-6 on anything.
  8. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    Cat6 cables are much more expensive though.
    Now lets get back on topic.
    Oclocker: Yea, it would be REAL COOL if Baybus.co.uk stocks them!
  9. Geek
    Geek What's a Dremel?
    21 Nov 2001
    Also IIRC Cat-6 has a thingy on the inside of the cable that looks like a plus sign, separates the pairs (i.e. green/white-green has its own quadrant of the cable), and has a more temperature-resistant coating. The coating thing may have just been this one particular type of Cat-6, though.
    Gordon
  10. dearkook
    dearkook What's a Dremel?
    28 Apr 2002
    I got a bunch from Molex for free just ask for some samples(Theres a free sample option on there website), I got mine within 3 days. Don't go abusing them tho they rock when it comes to free samples!!!
    Thanks
    Kook
  11. the_modder
    the_modder What's a Dremel?
    18 Dec 2002
  12. Oclocker
    21 Jun 2001
    Swines never did send mine & yet I wanted to buy loads :( Probably sent instructions to the UK muppets who ignored it because.. well because they are muppets.. :)
  13. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    Agreed and well said!
  14. jcy0001
    jcy0001 What's a Dremel?
    26 Apr 2003
    Oclocker: whats the part number at molex for the right angle one? i wonder if they come in black? what can you use to paint them black? those are the bomb ive been looking for them for months now saw them first at extreme mzh but they dont seem to want to answer questions there. does anyone know sites in asia that caries these?
  15. iggy
    iggy Minimodder
    24 Jun 2002
    never got mine either, i did get an email saying they were discontinued tho :/
  16. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    Same here.
    Then I requested another model number and they said they recieved the request... but then nothing happened.
    Emailed ScorpionMod a couple times regarding placing an order... no reply back.
    Checking on Farnell almost daily... nothing happened.
  17. Jordanis3r
    Jordanis3r Jigsaw Master
    8 Jan 2002
    dug this up because i need some pretty sharpish in the next week or so ... any one got some ?- need about 6 or so ?- need to source them in the UK ...
  18. Miku
    Miku What's a Dremel?
    11 Mar 2003
    Too bad scorpionmods.com doesn't sell VGA coolers:waah:
  19. Seal
    2 Feb 2003
    nope non from uk that i know of or have found, order them from scorpion thats what i did and i got them within a week easily
  20. Revv23
    Revv23 What's a Dremel?
    2 Jul 2003
    Cool, thanks. :)
