Cooling A few newbie questions about WC
Discussion in 'Hardware' started by ThureBusk, 6 Jul 2002.
  1. ThureBusk
    ThureBusk What's a Dremel?
    6 Jul 2002
    First I was planning on the 3R System's "Poseidon" watercooling sys., but it's still some weeks untill released. Then I thought to myself that I would investigate the net to find out what this watercoolingbuiz is all about. I have been browsing the net for nearly 2 whole days now, but still I have a few questions.
    I wanted a simple system for my warm AMD 1.33Ghz. At an american site they said that I didn't need a rad, I could use a big hollow copperplate, but is that true?
    Also Im a bit confused about the block. Some sites claim that the maze is the most optimal, and others claim something else, but what works best for a very warm CPU?
    Is a res a nesessaty? Can't you make a closed system only with a rad?
    Don't you think that my small system can use the DD Maze 3 with out it breaking/leaking?
    Lastly could I get an advise on a setup?
    I was thinking of using the Eheim 1048 or maybe the Eheim 1005 pump. The rad could be a Neptune 'The Deep' Radiator.
    Now comes the block, and this im not sure of... could I use an Koolance CPU-100 CPU Copper Cooler Kit or the DD2 or DD3 and should it be a 3/8 or a 1/2?
  2. *mat-ster*
    *mat-ster* What's a Dremel?
    10 Mar 2002
    Welcome ThureBusk the Dane :)
    1) What is the Poseidon?
    2) Have a look at these sites
    For Technical Info and "The most logical set-up"
    http://www.procooling.com/articles/html/cooling_technologies_explained4.shtml#H2OCool
    http://www.procooling.com/articles/html/unaclockers_h2o_buyers_guide_-.shtml
    http://www.voidyourwarranty.net/review/review.php3?r1=h2oguide/index.php3
    Good Guide
    http://www.coolhardware.co.uk/modules.php?name=Forums&file=viewtopic&t=149
    3) Yes you do need a Rad. Thats what a big copper tube is I suppose, but why not get a radiator designed for this purpose + smaller and more efficient.
    4) An inline air-trap like this is a good idea (remove bubbles from system)
    5) If you go for a maze 3 I would get the copper topped one.
    6) Ehiem 1048 with 1/2"
    7) You could always buy a ready to roll system like the Koolance or the Swiftech but mor fun the "pick 'n' mix" way
    http://www.theoverclockingstore.co....8ad84867c06e5461ce12169dc569e6&categoryid=100
    http://www.pclincs.co.uk//acatalog/PCLincs_Online_Store_Water_Cooling_18.html#qp
    Mat
  3. SiGmA_X
    SiGmA_X What's a Dremel?
    8 Jun 2002
    I bought my setup for $107, with out piping. I really love it. Here's what it has:
    Gemini Cool HP WB (Some say the best out there) from DTekCustoms - (http://dtekcustoms.com)
    VIA Aqua 1300 Pump from BeCooling (http://becooling.safeshopper.com/index.htm?668)
    If I were you, look around at everything before making a decision. And really look at DTek. They have some great stuff, and kits too!
  4. ThureBusk
    6 Jul 2002
    Thanx!:D *mat-ster* exelent guides!
    1) "Poseidon" is a Whatercooler kit, ready to roll from 3R systems.
    Im sorry but I only have this Korean link to the "Poseidon"
    http://www.3rsystem.co.kr/product/tuning/poseidon.htm so you can't really make much of it, but I think it will be fairly cheap and reliable.
    2)I think it's hard for a newbie to see through what kind of rad you should buy to get the results you want. Fx I was looking at this rad http://becooling.safeshopper.com/17/48.htm?668 but will that be efficient enough with two fans on?
    Could you recommend a fitting rad?
    3)I have tryed to find the Maze 3 with coppertop, but have been unable to find it for an AMD setup, so I might just consider another block. In the second artikel there is a link to the UnaBlock. Do you think this is an ok block?
    http://becooling.safeshopper.com/6/117.htm?83
    I got to think. On an AMD it is the little black square there needs the cooling, right?
    4) I like "The tube" too, and if you'r a DIY it's easy to make.
    You could actually make a quit cheap kit with the rad and the unablock and the DIY Tube.
    One last Q... How much water does a normal small system like mine need? I was thinking that if you have 1 liter of water and an ok rad, then the water would always be cold, but can you settle for less, like ½ Liter or somewhere between?
    ThureBusk the Dane
  5. *mat-ster*
    10 Mar 2002
    Hello SiGMA ;)
    I agree with SiGMA DTek Offer great kits..... Get the Polycarb topped blocks if you really want the show!
    Try this link out for other suppliers.........
    http://forums.bit-tech.net/showthread.php?s=&threadid=9950
    It may be a good idea to hav a look at some of the excellent German suppliers - the guy to ask about this would be Elemental
    My German is non-existant so he could give you some pointers on this.
    Thure the Dane could you help me out and tell me what this site is like ? http://www.crutam.nl/
    ;) Mat
  6. ThureBusk
    6 Jul 2002
    Oh sorry Sigma, forgot to say hellow and thanks for the advise!
    Well I can help you a bit with the page, if you want it partly translated. I dont speek dutch, but I can read some, 'cause it's kinda mix between german, dainish, english, flam and french. *schhhh* don't ever say that to a Dutch person, they don't like that :-D
    Else I think it's kinda weird. They don't say how you can pay for the merchandise. That normaly stops me from buying if you can't use a secure server. Maybe you have to mail them and ask!?
    Well you can order all their products by mail. I gues that it's this mail: crutam@wanadoo.nl , or you can call or fax your order to them.( dont forget the national code :) )
    When theres a NV behind the product it means that theyr out of stock.
    I take it that it's the Power Supply your interrested in? Well as far as I can understand, they will get the 300W on orders, it is not a stock product.
    If theres more you'd like translated or commet on, please don't hesitate to ask (and point out) :p
    Why do the make "polycrap"topped blocks if theys so bad and break?
    How do I find and contact Elemental?
  7. ThureBusk
    6 Jul 2002
  8. relix
    relix Minimodder
    14 Nov 2001
    Dude, I'm a belgian! And german, danish, english and french have faked our language! We don't fake people!
    :D
  9. ThureBusk
    6 Jul 2002
    hehe Relix :D I only said it about dutch, not belgish (have a few belgi friends)
    Mat
    I found this kit and thought it looked Ok, whataya say? I thought of adding "the tube" to the system to complete it.
    http://www.coolerkit.dk/product.asp?product=1&page=1
    It uses the MAZE2 block... pure copper topping :D no "polycrap" and the Eheim 1048 pump.
    I just don't understand why they don't have a resevoir for the setup...
  10. Coolrunnin
    Coolrunnin What's a Dremel?
    20 May 2002
    ThureBusk m8,
    I'd definitely recommend the Tube res from OCPC - I've been really pleased with mine, so much infact Jess is making me a custom sized one to fit my case a little better then the 250mm one I'm using ATM.
    I've had two Maze 2s (one 2-2 and one 2-1) both are still in great working condition and over a year old (I got one second hand!). Just lap all the top sides to 1500 grit smooth then polih with metal polish and coat with clear laquer and you'll have a luurvly shiny block that people will go 'WOW' at :D Mine are both finished like this and still have a great deep shine finish :)
    The rad will be O.K. but don't expect it to perform as well as a high flow rad like the BIX or OCPC the Deep :) It will work tho' :)
    Also, I'd consider changing to thick wlled silicon tubing as well, just as PVC ages and become brittle with some coolant additives (like WW) whereas silicon will last years and is cheap :D
    Good luck with ya coolng :D
  11. relix
    relix Minimodder
    14 Nov 2001
    lol 'belgish' doesn't exists, we speak dutch also, with a very differint accent yeah, but it's dutch (well, actually we speak "flemish", but that's a dialect, not a language)
  12. *mat-ster*
    10 Mar 2002
    Go for it Thure,
    Hav a good read of the articles in particular the procooling ones.
    That looks like a good deal.
    Mat :)
  13. ThureBusk
    6 Jul 2002
    Thnx guys!
    I think im getting there... Now I more or less knows what this' all about.
    Do you have some pix of your systems you can post here, so I can see what kind of things you use?
  14. Haddy
    Haddy World Domination
    22 Jan 2002
    DAMN U BELGIANS AND UR WAFFLES!!!!! :D :lol: :lol: :D
