a few questions
Discussion in 'CCL Computers' started by Thecraigyo, 21 Nov 2011.
  1. Thecraigyo
    Thecraigyo What's a Dremel?
    21 Nov 2011
    Am think of buying a computer from CCL and i want a decent gaming system but havent got the funds atm so do yo think it would be a better idea to buy a ok system with a better motherboard and prosessor etc so as i can upgrade later?
  2. DanSonley
    DanSonley What's a Dremel?
    20 Jan 2012
    it will cost you more if you get cheep stuff now in the long run. personally i would wait. unless you don't have anything to use right now.
    if you can upgrade parts individually that is a good option. like if the mobo is compatible with your current cpu then buy it in parts.
    buying all with cheep parts will mean you are buying the expensive and cheep. can also mean ending up with cheaper replacements to keep to your budget.
  3. varkanoid
    varkanoid Professional Dribbler
    18 May 2010
    cant really say without you listing what you have now, and what your budget is.
  4. dunx
    dunx ITX is where it's at !
    1 Sep 2010
    Do it right once, I bought my big-rig a piece each month, £200 MoBo, £240 CPU, DDR£ £170, £230 GPU, and just had to wait...
    dunx
    P.S. Yes that was a while back, almost fancy a 2011 set-up for Easter...
  5. rodeltt
    rodeltt What's a Dremel?
    12 Mar 2012
    We don't know what you existing MoBo is but if you don't have an SSD that could be worthwhile upgrade to extend its life a little longer.
