Hi just wondering if the 850w Silverpower SP850 - A2D is a good power supply, have looked on the internet but can't find any reviews. It is currently available on scan for £93.14 inc vat. Thanks in advance
Any particular reason why you need a 850w psu? are you using more than 2 gpus? in terms of power hungry gpus
Well I suppose I want to be running an sli setup in the near future. At the moment I wouldn't require 850w but it would save me an upgrade in the future. I have also considered the corsair 750w non modular psu, i would be ideally looking for a 700w plus one. Doesn't have to be modular as I will be buying a full tower case. Thanks
be quiet! Dark Power Pro 750W. It cost me a little over £100 and it's modular, with the biggest selection of cables I've ever seen in a PSU bundle. Bit-Tech review for you. It's the 650W model here, but it's about the same. A very good unit.
the problem is with the be quiet 750w at most stores it costs £130 but i have found one for £115 http://www.cclonline.com/product-info.asp?product_id=34449&tid=frooct shame really they used to cost £105
