Video A Guide to Drill Bits (The Modding Toolbox)
Discussion in 'Article Discussion' started by Dogbert666, 6 Apr 2018.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Confused about which drill bits you need for your current modding project? Fear not! In this first episode of our Modding Toolbox series, Alex takes you through the major types and what they're used for.
  2. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    What toolbox would you recommend?
  3. Mr_Mistoffelees
    26 Aug 2014
    As we say here in Somerset, a gert big-un.
  4. Cheapskate
    13 May 2007
    I did NOT just hear a yo mama joke. :lol:
    @MLyons - Multiple small, cheap, portable ones. You want something you can actually lift when loaded, and strong enough you don't rip the handle off.
    If you are looking for a shed queen I'd go with an armored file cabinet or something you can bolt to the floor.
  5. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Yeah as Cheaps says having a few smaller ones works better, although don't go too cheap as they tend to be made of the more brittle stuff.
  6. MLyons
    3 Mar 2017
    ye olde chinesium
Tags: Add Tags
