Cooling A new waterblock to see to believe
Discussion in 'Hardware' started by ICE-COOLER, 4 Apr 2002.
  1. ICE-COOLER
    ICE-COOLER What's a Dremel?
    4 Apr 2002
    This is a new sweat waterblock from Germany:
    the complet set
    :dude: :dude: :dude:
    here my temp with xp1900 and one156 W Peltierelement
  2. Randland
    Randland What's a Dremel?
    5 Feb 2002
    Just a couple of questions:
    1. Is it all copper, or copper/aluminium
    2. How much did it cost
    3. How big are the connections
    4. Are there any other reviews of it
    5. What is the manufacturers website
    6. Did you order it from them, or from another site
    It does look really cool, but I hope the copper hemisphere isn't solid, it seems that that would not take heat away as effective as if those groves went all the way to the cpu.:)
  3. ICE-COOLER
    4 Apr 2002
    1.yes it all copper
    2. will of NEOLEC I don't develop any idea and build this Waterblocks with the Distri with you fixed cost this one
    3.the fluidconectors it 8mm
    4.no Review is published yet
    5.as well as everything is in the trade will I let you know
    6.this will give set with you directly, too
    I have here still pictures of the Case.So the system introduced on the CeBIT in Hanover
    it runs turn off this one pumps out lowerly fully read at 63 °C circulate absolutely noiselessly
    excused please, I hope for my terrible English you can read it
  4. Elemental
    Elemental What's a Dremel?
    28 Dec 2001
    Die Kugel in der Mitte ist aus Kupfer, aber die wird doch von einer Aluplatte fixiert, oder? Sieht zumindest so aus!
    mfG
    Elemental
  5. ICE-COOLER
    4 Apr 2002
    Hi:D
    nein der Kühlkern ist im Acryl mit Nitril O-Ringen befestigt und wird durch die in das Gehäuse eingefrästen kanäle vom Wasser durchspült Boden des Kerns übrigens 2mm
    Hi
    no, the cool core is fastened in the acryl with Nitril O rings and is through the channels one milled into the case of the water through bottom of the core flowed by the way for 2 mm
    here still a render picture
  6. TiTch
    TiTch h2o cooled
    19 Oct 2001
    We have seen this block before. It does look nice, but I recon the cooling solutions one has a better serface area due to its pin design.
    How does the cold plate attach for using a peltier.
  7. ICE-COOLER
    4 Apr 2002
    who have you seen this Block before??
    i have this Modell komplete new created
    i am using 2 coldplates for mounting the block and Using a Peltier
  8. TiTch
    TiTch h2o cooled
    19 Oct 2001
  9. Randland
    5 Feb 2002
    They appear to be the same picture, just this one is blown up a little bit and blured to look better:)
  10. ICE-COOLER
    4 Apr 2002
    my cooler is already I had a News before this peters out has this beautifully landed her also here it is the same cooler
    :D :D :D
  11. [GiB] Spawny
    [GiB] Spawny Xqpack Lovin
    2 May 2001
    Sorry ICE - COOLER beat you to the post by some margin looks nice and a real beauty for those that have windows to show them off.
    For me the jury is still out as I believe like TiTch there are better. It will be interesting if they make the UK market. There is a real gap for resellers to pick these up, as I feel there is a real demand for them in the UK.
  12. ICE-COOLER
    4 Apr 2002
    I work to this side the company Neolec already has as said sale partners in UK and the Aquastar also will therefore be available with you I arrange the Samples for all the hardware sides for various Reviews at the moment if her still no good one knows the one objective test get down a mail woolenly sends to me, please I then will take contact with people and a set send
  13. Haddy
    Haddy World Domination
    22 Jan 2002
    well hell just about any block will kick ass with a 156w tec
  14. Koolvin
    Koolvin The Modfather
    12 Mar 2001
    Sie gute pals mit UWE dann?
    Wir reviewd das CS-Material und -es sind noch innen Gebrauch zu diesem Datum, fallenlassen mich ein email an Koolvin@bit-tech.net, oder ICQ ich sehen mein Profil.
    Greetz.
  15. ICE-COOLER
    4 Apr 2002
    make better whit a simple pc power supply on 12V
  16. Koolvin
    12 Mar 2001
    Stay tuned folks for a UK Exclusive review - right here on BiT-TEch.net
  17. [GiB] Spawny
    2 May 2001
    Hallo Eis-Kühlvorrichtung
    Titch und I unser Einschiffen auf doppelten vorangegangenen, Wasser abgekühlten Projekten und werden sie über dem Forum und meiner eigenen Site laufen lassen. Modded in hohem Grade Fall mit Fensternotwendigkeit ein Schwerpunkt und Perspexblöcke erstellen diese Auswirkung.
    Erhalten Sie in der Note, wenn Sie keine Zusammenfassungen oder Prüfung benötigen. Wir können sie zu den BRITISCHEN Resellers als neues Produkt auch fördern, wenn Sie anfordern. Es Sitze innen gut mit Koolvins Anlage und mir ist sicher, daß es die bestmögliche Wahl als Großbritannien Exklusives ist.
    Thats enough German for me, can't wait to Koolvins review :D
  18. Elemental
    28 Dec 2001
    He guys, I suggest you stay with english! I hardly understand your german! (or babelfish's german ??? )
    cu
    Elemental
  19. ICE-COOLER
    4 Apr 2002
    my English isn't particularly good. but your German oh oh.
    however, this has left at the English can I for reading
    Thanks and greetings from Germany
    :D
  20. [GiB] Spawny
    2 May 2001
    English Version
    Hi ICE-COOLER
    TiTch and I our embarking on a Double headed, water cooled projects and will be running them over the forum and my own site. Highly modded cases with windows need a focal point and perspex blocks will create that impact.
    Get in touch if you need any more review sites or testing. We can also promote them to UK resellers as a new product if you request. It fits in well with Koolvins rig and I'm sure it will be the best possible choice as a UK exclusive.
