a "sinking" feeling
Discussion in 'Hardware' started by Amorphus, 3 Apr 2003.
  1. Amorphus
    Amorphus What's a Dremel?
    25 Feb 2003
    get the joke?
    I got a Thermalright SLK-900U (it came in today... !)
    anyways, I was holding it, admiring it, and suddenly I notice a flash of silverish, instead of the orangish sheen of copper. so I look again. and I notice more and more flashes of silverish.
    I'm starting to suspect that the SLK-900 is actually copper-plated aluminum, or worse, anodized aluminum...
    doesn't matter, the things supposed to perform well anyways, and the fins, at least, seem to be copper, but its kind of offsetting, if you know what I mean.
    anyone else have a SLK900 they can look at and see if I'm just drawing the wrong conclusions?
    and mine came with a slightly ridged base... it looked like the markings on metal that just got milled flat, if you've worked with a milling machine before, and it has texture to it, too. I can actually feel the ridges if I run my fingernail over it.
    I'm gonna go pick up some sandpaper later this week and lap it before I put it on my CPU... eh... two hours down the tube...
    do you get the joke yet? haha... Amorphus made a funny...? hah.... eh.... :waah:
  2. WireFrame
    WireFrame <b>PermaBanned</b>
    24 Feb 2003
    You're groping your heatsink? I feel your pain..... ;)
  3. Carbon
    Carbon Banned
    8 Jan 2003
    if you suspect that it isnt pure copper, then dont use it, the site says "all copper" :|
  4. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    Knock off being sold as a SLK900?
  5. Iceman
    Iceman Staff
    13 Feb 2003
    The SLK900 IS 100% copper I can assure you, if it weighs a tonne then it's definitely copper :)
  6. Carbon
    Carbon Banned
    8 Jan 2003
    where did you get it from? i would complain to them
  7. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    Are you sure it just isnt a flash from an extra bright light int he room? If it is silvery in indirect light then its probably defective in some way, otherwise it could just be reflective.
  8. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    If it's not a knock off you can sue the company for mis-advertising.
  9. Amorphus
    25 Feb 2003
    heehee, it was solder.
    I wanted to see the reactions I got. it's 100% copper, I assure you.
    the fact that the whole thing isn't made out of a solid block of copper is kind of disappointing, though. :p
  10. Carbon
    Carbon Banned
    8 Jan 2003
    BAH! damn you *shakes fist*
    Someone ban him ;)
