a small website tweek
Discussion in 'Feedback & Suggestions' started by thorilan, 5 Sep 2003.
  1. thorilan
    thorilan What's a Dremel?
    25 Aug 2003
    ok i love this site but there is one thing that i think would be very usefull for people that have high posts per page settings ( saving band width where possible :thumb: )
    this bar is very helpfull when you want to go through many areas of the website like say i want to go back 1 level or change directories .
    the problem is when you are all the way down at the bottom of the page you have to scroll all the way to the top to get back to that bar.
    well at overclockers dot com they have it at the top and bottom of the page which i and many others find very very convienient.
    im not a web designer but i dont think it would take very much to add that line at the bottom and am asking if it could possible be added in
    thank you for your time and i love the site.happy modding :dremel:
  2. moose
    moose What's a Dremel?
    12 Mar 2001
    Like what's now below, when viewing a thread?
  3. DeX
    DeX Mube Codder
    22 Jul 2002
    Oooh Funkeh (me points to sig ;)). I like. :p
  4. Supercool
    Supercool Gone.
    31 May 2003
    ooo yay, the breadcrumb is at the bottom of the page too :clap:
  5. thorilan
    25 Aug 2003
    woot great that realllllly helps on longer posts !!!!
    thank yu very very much
  6. Bruno_me
    Bruno_me Fake-ad‎min
    30 Mar 2003
    go breadcrumbs!!!
    /me makes noises like pigeons
  7. Lazy
    Lazy Meow?
    13 Nov 2001
    no one else knows what the home key on a keyboard does then? :D
  8. moose
    12 Mar 2001
    Good tip - still not ideal if you happen to be in 'mouse only' mode :)
  9. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    Home brings you to the start of a line which you have already typed (i think)
  10. Lazy
    Lazy Meow?
    13 Nov 2001
    takes me to the top of the page
  11. moose
    12 Mar 2001
    You're both correct. It depends if your cursor is in a text box or not.
