CPU A320 BIOS update
Discussion in 'Hardware' started by Greentrident, 19 Nov 2022.
  1. Greentrident
    Greentrident Minimodder
    10 Jul 2009
    I have an A320M-H rev 1.2 and a Ryzen 5500 both of which should play nicely together if I update the BIOS. Has anyone done this and is there any way of flashing the BIOS without buying another CPU? If so cheapest I've seen would be from CEX for an A10-9700E £25 plus postage which I'm slowly resigning myself to getting and then having to sell back or sell on! Just wondering if anyone can advise another solution!?!?
  2. Mr_Mistoffelees
    26 Aug 2014
    Last time I had the same problem, I bought a CPU from amazon, did the update, then returned the CPU for a full refund.
  3. Greentrident
    10 Jul 2009
    That's one way to do it! Was it an a320 motherboard and if so did it work OK with the 5xxx cpu?
  4. Mr_Mistoffelees
    26 Aug 2014
    Greentrident likes this.
  5. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    You could always ask in the marketplace and see if someone could either loan you a CPU or do the flash for you.
  6. Greentrident
    10 Jul 2009
    I may well do that. Failing that CEX will have to suffice!
  7. Arboreal
    21 Jan 2011
    I can help there @Greentrident. I have a Ryzen 3 1200 that is surplus and is due to go on the MP, which you could borrow if it'll do the trick.
  8. Greentrident
    10 Jul 2009
    Thanks, let me have a think whether I am going to get trouble to doing anything with it all in the near future - if not I'm probably better waiting or buying a cheap one rather than sitting on yours!
