Abit BIOS vs PC Geiger
Discussion in 'Hardware' started by JSVRamirez, 4 May 2002.
  1. JSVRamirez
    JSVRamirez What's a Dremel?
    3 May 2002
    And the winner has been the Abit SD7-533 BIOS since Tuesday.
    For some reason the Abit BIOS causes the Geiger not to function. Before BIOS screen kicks in, it works fine. In BIOS settings it works too, of course with readings of zero. It works perfectly on my wifes old HP Celeron. Now I have tried it in every PCI slot, including #3, with no luck. I have turned things off in BIOS, turned things on, and Im running out of ideas. IOSS says that I need to disable "Auto Detect DIMM/PCI Clk" because I needed to disable the PCI Clock Suspension.
    Anybody have any idea why it isnt functioning? I have done plenty of BIOS modding to try to fix it but have had no luck. The Debug POST code monitor worked fine and the switches work great. Just that @X#$&* PCI monitor! Anybody have this problem?
    Abit SD7-533
    1.6A Northwood
    256mb PC2700
    ATI Radeon 8500
    Maxtor ATA100 rpm 7200
